Threads: 689
you can create second IFTTT command for "HOLD ON". just create multi IFTTT command is ok.
Threads: 2
Ok, is this behavior possible with one switch?
The light is off
single click - the light turns on to the last brightness value
single click - the light turns off
hold - the light increases in brightness
hold again - the light decreases in brightness
Threads: 689
maybe you need multi times of "hold", you can test it.
Threads: 689
do you means, create some different HOLD ON trigger, send customsize protocol command to dimmer controller?
now "KCS" firmware not support this, but i will save your suggestion.
Threads: 2
I tried many different things...
Currently, it is not possible to get this behavior. Even creating multiple IFTTT commands.
Will this be possible in the future?
Otherwise, the KCS system is not an option for me and I will need to use ESPHome and configure everything in home assistant.
I would prefer to use the KCS system because it works immediately after a power outage.
Thanks in advance!
Threads: 689
your requirements suggest use ESPHome config in yaml. ESPHome also work locally.
