03-01-2024, 02:57 PM
How do I get access to the I2C bus? I want to add an LCD display.
TIA...
Wick
TIA...
Wick
I2C
TIA... Wick
03-02-2024, 01:39 AM
A8 have a i2c extender interface on PCB, you can use it SDA,SCL connect to your display. such as SSD1306 i2c LCD display.
03-03-2024, 08:49 AM
i'm triyng to add a pcf8574T via i2c but the kc868-a8 (I'm using esphome) doesn't see it during the scan. I checked the pcf with an Arduino Uno and everything works properly.
with Arduino I at first did a scan to find the right address. then i added the following code on the KC868-a8 #additional pcf8574t - id: 'pcf8574_hub_in_2' # for input channel 9-16 address: 0x27 but I had no result many thanks for your suggestion!
03-03-2024, 10:24 AM
take a photo , how you connect wire with i2c module. make sure you have set the correct i2c address.
Users browsing this thread: |
