Threads: 4
02-28-2024, 10:55 AM
Hi Have a question about a how best to connect a signal that is about 1.2 - 2 volt.
I presume I can not use the dry contact input 1 - 8 a they are 12v ?
Is there a way to get the board to detect a small 1.2 volt signal
Can I use inputs S1 - S4?
Thanks
Threads: 691
you need use analog input port. that is for 0-5v
Threads: 4
My problem is I have some inputs I can connect directly to the digital inputs on the KC868-A8 but I have some inputs that are shared with an alarm panel they are alarm sensors, Previously they were connected to an Arduino to the digital input with a sheared common ground, Worked fine.
But I can't connect them to the KC868-A8 digital inputs because it can't accept the low signal.
Is there an expander that will allow me to connect the low level signal inputs with shared common ground?
Thanks
Threads: 4
Do you have an expander that will work with the KC868-A8 that will give me 6 or 8 channels?
2 channels is not enough.
Thanks
Threads: 691
A8 have i2c extender on PCB, you can easy to add i2c analog input module
Threads: 4
Do you make a suitable product or can you give me a link to something you recommend?
Can't seem to find many.
Thanks
