Retrofitting an RTC battery on the I2C bus in the KC858-A-8 V1.6 panel
Greetings to all!
I have 2x KC868-A-8 V1.6 panel.
Our project requires that the panel does not forget the exact time setting even after a power cut.
It is possible to integrate  a RTC I2C module -with battery- into the I2C bus, for example  same ways as KC 868-A6 have?
For example DS3231 ? https://www.aliexpress.com/item/10050064...QwHg7&mp=1
Thanks Your support!
Mihaly
sure, you can add extend DS3231 module with A8's I2C extender.
(03-17-2024, 12:44 AM)admin Wrote: sure, you can add extend DS3231 module with A8's I2C extender.
THANKS  i wil test it!
