H32B Pro ESB32 pinout?
Where is the equivalent of this page for H32B Pro please?
https://www.kincony.com/forum/showthread.php?tid=282
Thank you!
H32B Pro only can use ESP32 send serial command to ARM CPU. all INPUT and OUTPUT not connect with ESP32 directly, they connect with ARM CPU's pins.
I'm sorry, I don't know enough to understand your answer.
I followed your videos to understand how to create the config for ESP32 starting with this one:
https://www.youtube.com/watch?v=2XZ-xG5D...2V&index=6
The videos are for the A modules; what is the equivalent for H32B Pro? How can I create the config so that the board appears in Home Assistant with the switches etc.?
KC868-A series board made by ESP32 module. integrate to home assistant by ESPHome.
KC868-HxB series board not by ESP32, so integreate to home assistant by MQTT, here is details: https://www.kincony.com/kc868-h32b-integ...-mqtt.html
This is disappointing but thank you for the answer
