KC868-A64 REV 1.3 - Ethernet is not Working
I bought 3 board KC868-A64 REV 1.3 and in one of them the Ethernet port it's not working.
I tried using exactly the same ESPHome Config, Eth Cable, Power on this one than the another two and this one is not working properly.
[D][esp32.preferences:114]: Saving 1 preferences to flash...
[D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[C][ethernet:029]: Setting up Ethernet...
[I][ethernet:138]: Starting ethernet connection
[W][ethernet:155]: Connecting via ethernet failed! Re-connecting...
This is the basic config that I'm using:
  friendly_name: test
esp32:
  board: esp32dev
  framework:
    type: arduino
  encryption:
    key: "wsIfuavsl9mVb28lgRojJDQNGvabMa67BszAFCmc37s="
ota:
  password: "d0a70c2dc2ca1d1325dea05d43c39eb0"
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
What it's the process to do a RMA?
after you download firmware, can you try re power on? just let A64 power OFF->ON.
(03-17-2024, 12:52 AM)admin Wrote: after you download firmware, can you try re power on? just let A64 power OFF->ON.
I did it multiples times, using wifi works as expected, looks like the eth chip it's not working properly
can you try to weld the LAN8720 chip.
