Programmed in ESPHOME
Hello. I have a Kincony F16 that has been programmed in ESPHOME so that the digital inputs act on de "relay" outputs as a wall switch, the question is. Is there a way to keep working like this but add a condition that if a Home Assasistant entity is active, It blocks the relay from turning on in any wall and cannot be turned off? In ESPHOME of course. If possible, can you give an example? Thanks.
"It blocks the relay from turning on in any wall and cannot be turned off" what's means? i don't understand.
