How to connect button switch module
How to connect wired switch panel with touch sensor (e.g. https://www.aliexpress.com/item/32761180385.html) to button switch module for KC868-Hx relay (https://www.kincony.com/button-switch-mo...oller.html).
These types of switches are fashionable and look better than the standard ones ...
Maybe there is one that was powered by DC12V and worked with Kincony button switch module?
now touch panel almost use by AC220V , it directly to control AC220V load ON/OFF. because it's use touch sensor, so the self-reset type switch panel is more stable.
