KC868-A32 Shutter with percentage
I have a KC868-A32 device, and I would like to use it for roller shutter (blind) control, ideally with integration into Home Assistant.
I’ve tried using ESPHome, but the outputs were only recognized as switches, not as covers.
My questions:
  1. How can I use my KC868-A32 for roller shutter control, including percentage-based position control?
  2. Which firmware is best suited for this purpose: ESPHome, Tasmota, or Tuya?
1. i think you can set the "delay" time for the relay. you can calculate the time shutter open/close time. if use by motor, use two relay control one motor, enable INTERLOCK group in KCS firmware.
2. this just set by KCS firmware, see the photo.
[Image: output-webpage.png]
[Image: interlock.png]
Answered here
https://www.kincony.com/forum/showthread...1#pid21721
