Relay connection
Hello, can you provide me with a wiring diagram for a relay on an output of the KC868-A16V3 board?
Thank you.
just OUTPUT connect to relay's coin, A16v3 support use by DC12V or 24V power supply, so your extnd relay's coin can use by 12v or 24v version.
(05-29-2025, 11:47 PM)admin Wrote: just OUTPUT connect to relay's coin, A16v3 support use by DC12V or 24V power supply, so your extnd relay's coin can use by 12v or 24v version.
Thank you for your reply.
No need for a freewheeling diode?
not need.
Sharing diagrams for a specific electronic device like this could be misleading or potentially dangerous without knowing the full context of your project, and it's best to refer to the official documentation from the manufacturer.
(05-30-2025, 02:55 PM)cln Wrote: No need for a freewheeling diode?
Someone in an EE forum has redrawn part of the KC868 circuit diagram to make it easier to understand, in this one you can see that there's already a snubber diode across the output:
