11-02-2026, 03:49 PM
Hello KinCony team,
I have a problem with my KC868-A4 board.
Problem:
Relay 1 switches ON and OFF intermittently when WiFi Access Point (AP) mode is enabled.
I have performed several tests using a simple Arduino sketch with no relay control code at all.
Test results:
Best regards
Natravn
Problem:
Test results:
- – WiFi disabled: No relay clicking.Code:
WIFI_MODE_NULL
- – Station mode, without connecting to any network: No relay clicking.Code:
WIFI_STA
- – Access Point mode: Relay 1 starts clicking intermittently.Code:
WIFI_AP
- The DS18B20 temperature sensor on GPIO13 works correctly in all tests.
- I have tried a different power supply. The problem remains.
- No external loads or devices are connected to the relay outputs.
- Relay 1 is the only relay that clicks.
- The LED for relay 4 stays constantly illuminated.
- Is this a known issue with the KC868-A4?
- Could WiFi AP mode interfere with GPIO2 or the relay driver circuit?
- Could this indicate a hardware fault on my board?
- Is there a recommended solution?
Best regards
Natravn
Hello KinCony Support,
