[arduino code examples for A8v3]-01 Turn ON/OFF relay by XL9555 chip
* This program controls a 8-channel relay board via a XL9555 I/O expander.
* It sequentially turns on each relay and then turns them off in a loop.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
* - 200 milliseconds between switching relays
#include <Wire.h>        // Include the Wire library for I2C communication
#include <PCA95x5.h>     // XL9555 I/O expander driver
#define SDA 8           // Define the SDA pin
#define SCL 18          // Define the SCL pin
#define DELAY_TIME 200   // Define the delay time in milliseconds
// Set I2C address of the XL9555 module
#define I2C_ADDRESS 0x22 // I2C address of the XL9555 module
PCA9555 xl9555_R1; // Driver object for the XL9555
  Wire.begin(SDA, SCL); // SDA on GPIO 8, SCL on GPIO 18 (according to your board's configuration)
  // Initialize serial communication for debugging (optional)
  Serial.println("XL9555 Relay Control: Starting...");
  // Attach the XL9555 to the existing I2C bus.
  xl9555_R1.attach(Wire, I2C_ADDRESS);
  xl9555_R1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
  // Preload HIGH so active-low relays start OFF.
  xl9555_R1.write(PCA95x5::Level::H_ALL);
  // Ports 0-7 are relay outputs; ports 8-15 remain inputs.
  // Direction bits: 0 = output, 1 = input.
  xl9555_R1.direction(0xFF00);
  // Sequentially turn on each relay
  for (int i = 0; i < 8; i++) {
    xl9555_R1.write((PCA95x5::Port::Port)i, PCA95x5::Level::L);   // Turn on the relay at pin i (LOW means ON for the relay)
    delay(DELAY_TIME);          // Wait for DELAY_TIME milliseconds
  // Sequentially turn off each relay
    xl9555_R1.write((PCA95x5::Port::Port)i, PCA95x5::Level::H);  // Turn off the relay at pin i (HIGH means OFF for the relay)
.zip   1-output-9555.zip (Size: 1.01 KB / Downloads: 3)
.zip   1-output-9555.ino.merged.zip (Size: 193.91 KB / Downloads: 3)
