[arduino code examples for A8v3]-02 Read digital input ports state by XL9555
* Description:
* This Arduino program reads ports 8-15 of an XL9555 I/O expander
* and prints their states to the Serial Monitor. The state of
* each pin is represented as a bit in a 16-bit value, where each bit corresponds
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - XL9555 I2C Address: 0x22
#include "Arduino.h"
#include <Wire.h>
#include <PCA95x5.h>
// Define I2C pins
// Set I2C address
PCA9555 xl9555_IN1; // XL9555 driver object
#define I2C_ADDRESS 0x22
    // Configure all ports as inputs; only ports 8-15 are read below.
    xl9555_IN1.attach(Wire, I2C_ADDRESS);
    xl9555_IN1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
    xl9555_IN1.direction(PCA95x5::Direction::IN_ALL);
    Serial.println("KinCony B8M 8 channel input state 0:ON  1:OFF");
    // Keep ports 8-15 in bits 8-15, as in the original program.
    // Bits 0-7 remain zero; do not shift the input states down.
    uint16_t state = xl9555_IN1.read() & 0xFF00;
    delay(500); // Delay 500ms
.zip   2-digital-input-9555.zip (Size: 929 bytes / Downloads: 3)
.zip   2-digital-input-9555.ino.merged.zip (Size: 194.13 KB / Downloads: 3)
