friendly_name: a8v3
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
external_components:
- source:
type: git
ref: v1.4.0
# logger:
# hardware_uart: USB_SERIAL_JTAG
encryption:
type: W5500
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
pca9554:
- id: xl9555_hub
i2c_id: bus_a
address: 0x22
pin_count: 16 # XL9555: outputs 0-7, inputs 8-15
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 39
rx_pin: 38
- id: tuya_mcu_uart
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 9600
tuya_wifi_mcu:
# tuya mcu product id
product_id: qlvsreramxcldwek
uart_id: tuya_mcu_uart
wifi_reset_pin: 28
wifi_led_pin: 16
- platform: uart
uart_id: uart_1
pca9554: xl9555_hub
mode: OUTPUT
- platform: tuya_wifi_mcu
dp_id: 1
# hide from homeassistant ui
internal: true
bind_switch_id: "a8v3_output01"
pca9554: xl9555_hub
number: 1
mode: OUTPUT
dp_id: 2
internal: true
bind_switch_id: "a8v3_output02"
pca9554: xl9555_hub
number: 2
mode: OUTPUT
dp_id: 3
internal: true
bind_switch_id: "a8v3_output03"
pca9554: xl9555_hub
number: 3
mode: OUTPUT
dp_id: 4
internal: true
bind_switch_id: "a8v3_output04"
pca9554: xl9555_hub
number: 4
mode: OUTPUT
dp_id: 5
internal: true
bind_switch_id: "a8v3_output05"
pca9554: xl9555_hub
number: 5
mode: OUTPUT
dp_id: 6
internal: true
bind_switch_id: "a8v3_output06"
pca9554: xl9555_hub
number: 6
mode: OUTPUT
dp_id: 101
internal: true
bind_switch_id: "a8v3_output07"
pca9554: xl9555_hub
number: 7
mode: OUTPUT
dp_id: 102
internal: true
bind_switch_id: "a8v3_output08"
pca9554: xl9555_hub
number: 8
mode: INPUT
dp_id: 111
bind_binary_sensor_id: a8v3_input01
internal: true
pca9554: xl9555_hub
number: 9
mode: INPUT
dp_id: 112
bind_binary_sensor_id: a8v3_input02
internal: true
pca9554: xl9555_hub
number: 10
mode: INPUT
dp_id: 113
bind_binary_sensor_id: a8v3_input03
internal: true
pca9554: xl9555_hub
number: 11
mode: INPUT
dp_id: 114
bind_binary_sensor_id: a8v3_input04
internal: true
pca9554: xl9555_hub
number: 12
mode: INPUT
dp_id: 115
bind_binary_sensor_id: a8v3_input05
internal: true
pca9554: xl9555_hub
number: 13
mode: INPUT
dp_id: 116
bind_binary_sensor_id: a8v3_input06
internal: true
pca9554: xl9555_hub
number: 14
mode: INPUT
dp_id: 117
bind_binary_sensor_id: a8v3_input07
internal: true
pca9554: xl9555_hub
number: 15
mode: INPUT
dp_id: 118
bind_binary_sensor_id: a8v3_input08
internal: true
##pull-up resistance on PCB
number: 13
number: 40
number: 14
number: 48
## without resistance on PCB
number: 5
inverted: false
inverted: false
- platform: adc
pin: 7
name: "A8v3 A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 6
name: "A8v3 A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "KinCony a8v3");
A8v3-HA_XL9555.txt (Size: 8.27 KB / Downloads: 3)
XL9555 i2c chip:
