friendly_name: A16v3 Dual Network Demo
platformio_options:
board_build.flash_mode: dio
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
ota:
- platform: esphome
# Both network interfaces work simultaneously.
# Ethernet is the preferred default network.
# WiFi is the automatic fallback network.
network:
enable_ipv6: false
priority:
- ethernet
- wifi
# WiFi configuration
wifi:
ssid: "KinCony"
password: "a12345678"
power_save_mode: none
# W5500 Ethernet configuration
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO15
interrupt_pin: GPIO2
reset_pin: GPIO1
# I2C bus for SSD1306
sda: GPIO9
scl: GPIO10
frequency: 400kHz
# Read IP addresses from each interface independently
text_sensor:
- platform: wifi_info
ip_address:
name: "WiFi IP Address"
- platform: ethernet_info
ip_address:
name: "Ethernet IP Address"
# OLED font
font:
- file: "gfonts://Roboto"
# SSD1306 OLED display
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
update_interval: 1s
lambda: |-
// Title
it.printf(0, 0, id(font_small), "A16v3 Dual Network");
// WiFi IP address
const char *wifi_addr =
id(wifi_ip).state.empty() ?
"Connecting..." : id(wifi_ip).state.c_str();
it.printf(0, 13, id(font_small),
"WiFi: %s", wifi_addr);
// Ethernet IP address
const char *eth_addr =
id(eth_ip).state.empty() ?
"Connecting..." : id(eth_ip).state.c_str();
it.printf(0, 26, id(font_small),
"ETH : %s", eth_addr);
// Show current default network
if (id(eth).is_connected()) {
it.printf(0, 39, id(font_small),
"DEFAULT: ETHERNET");
} else if (!id(wifi_ip).state.empty() &&
id(wifi_ip).state != "0.0.0.0") {
"DEFAULT: WIFI");
} else {
"DEFAULT: WAITING");
// Ethernet cable status
it.printf(0, 52, id(font_small),
"ETH LINK: %s",
id(eth).is_connected() ? "UP" : "DOWN");
A16v3-Dual-Network-Demo-HA.txt (Size: 2.51 KB / Downloads: 1)
more details in ESPHome: https://esphome.io/components/network/#m...ce-support
