KC868-D16 dimmer controller MQTT configuration for home assistant fixed linear issue
#11
(01-20-2026, 09:24 PM)admin Wrote: make sure your mqtt broker password is <10 letters, is this ok?
yes. and just letters
post your yaml file by file at here, not copy and paste text.
The file:
https://www.dropbox.com/scl/fi/9ue47mq3s...1to4b&dl=0
Now, the d16 do not try to connect. exacly the same configuration and network.
Thamk you
best regards
set your ethernet mode to "DHCP", not use "STATIC", if also can't work , tell me, i will test it.
