"KCS" v2 firmware system
Threads
- "KCS" v3.0.3 firmware for A32 Pro controller (0 Replies)
- "KCS" v3.0.2 firmware for A32 Pro controller (0 Replies)
- "KCS" v3.0.1 firmware for A32 Pro controller (0 Replies)
- A16 kcs v2.2.4 delay sometime not working (1 Reply)
- "KCS" v2.2.5 firmware BIN file download (6 Replies)
- "KCS" v2.2.6 firmware BIN file download (0 Replies)
- "KCS" v2.2.4 firmware BIN file download (8 Replies)
- Send RF from MQTT (1 Reply)
- Firmware settings Backup (3 Replies)
- Kcs output off after x seconds (1 Reply)
- NodeRed MQTT and Single output State (1 Reply)
- "KCS" v2.4.9 firmware for M30 AC Energy Meter (0 Replies)
- "KCS" v2.2.2 firmware BIN file download (73 Replies)
- Problem with KC868-A16 Firmware (3 Replies)
- KC868-A16 Download, EtherNet Firmware and not open EntherNet (15 Replies)
- "KCS" v1.0.19 firmware BIN file download (2 Replies)
- DOA KC868-A16 (14 Replies)
- KCS Firmware and home assistant together ? (5 Replies)
- "KCS" v1.0.24 firmware BIN file download (35 Replies)
- Factory Default Firmware (3 Replies)
- "KCS" v1.0.7 firmware for A32 Pro controller (0 Replies)
- can i use kcs firmwar with kc868-16T ? (7 Replies)
- Request for Latest Firmware Update for KC868-E16T (5 Replies)
- Firmware Input (7 Replies)
- E16T IFTTT Limit and Logs (1 Reply)
- KCS DI/DO not working (14 Replies)
- kc868-a8 V1.5 flashing (12 Replies)
- "KCS" v1.0.5 firmware for A32 Pro controller (0 Replies)
- Kcs firmware for kc868-a6 (2 Replies)
- suggestion : Matter with KCS (1 Reply)
- DHT21 Sensor (3 Replies)
- KC868-AG disapeared from the WIFI network (18 Replies)
- Kcs question (5 Replies)
- KC868-server Ultrasonic and Gas sensors (5 Replies)
- Home assistant mqtt anolog sensor (8 Replies)
- KC868-A16 Section Control AgIO v5.7 (7 Replies)
- Can Use Diferent Firmware same time? (1 Reply)
- KC868-A32 temperature sensor (7 Replies)
- I connected temperature sensor. But the relay doesn't work (9 Replies)
- "KCS" v2.1.0 firmware BIN file download (8 Replies)
- KC868-A16 protocol_custom call rs485 using http? (3 Replies)
- A16S Modbus control (7 Replies)
- "KCS" v2.0.5 firmware BIN file download (14 Replies)
- KC868-A16 dead? (4 Replies)
- KCS http post ifttt/set (3 Replies)
- KCS Firmware multiple DS18B20 on the same GPIO (3 Replies)
- KCS firmware missing input options, only have reverse option (2 Replies)
- KCS save settings and upload to other board (2 Replies)
- KCS v2.1.9 firmware (7 Replies)
- Failed Automation and Conditional Control of Output 1 (13 Replies)
