01-05-2022, 07:05 AM
Code 5: //The demo code is PCF8574-DI You can copy the code to your Arduino IDE
[attachment=515]
[attachment=950]
#include "Arduino.h"
#include "PCF8574.h"
// Set i2c address
PCF8574 pcf8574(0x22,4,5);// 0x22 is address, IO4 is SDA IO5 is SCL
unsigned long timeElapsed;
// pcf8574.pinMode(P0, OUTPUT);
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P4, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P7, INPUT);
if (pcf8574.begin()){
Serial.println("OK");
}else{
Serial.println("KO");
uint8_t val5 = pcf8574.digitalRead(P4);
uint8_t val6 = pcf8574.digitalRead(P5);
uint8_t val7 = pcf8574.digitalRead(P6);
uint8_t val8 = pcf8574.digitalRead(P7);
delay(300);
[attachment=950]
