Node-Red-flows for KC868-Hx relay controller, suit for KC868-H2,4,8,16,32 relay controller ,support old and new version of all relay controller.
attachment=139]
I have problem when I import.
Imported unrecognised types:
* ui_switch
* iu_group
* ui_tab
before import flows , you need install these nodes for Node-Red:
1. node-red-contrib-ui-led 【LED UI】
2. node-red-contrib-ui-level 【Temperature】
3. node-red-dashboard 【dashboard UI】
I'm getting an error message after installing , missing ui-base.
6 Apr 14:14:11 - [info] Waiting for missing types to be registered:
26 Apr 14:14:11 - [info] - ui_base
What should I do?
(04-26-2021, 10:22 AM)Rhultin Wrote: [ -> ]Hi,
Everything fine, Reinstalled Dashboard
What should I do?
I have imported the flow to node red, changed the IP address and port of the TCP nodes.
How can I get these switches on the dashboard?
(11-14-2022, 01:41 PM)filiperod Wrote: [ -> ]I have imported the flow to node red, changed the IP address and port of the TCP nodes.
oh, just realized that the relays on this flow are only visible on a node red dashboard, which I have no interest in creating. I would like to keep the switches on the main HA dashboard. I can control the relays on the relay board, but can't get feedback from the board when a switch is manually operated on the expansion board.
Is there a way to connect these two ends:
attachment=1593]
