Full Version: Development
Development
Pages: 1 2 3
Threads
  1. Change in Web Interface? (1 Reply)
  2. How can I control 170 small 6V bulbs with MOSFET outputs (PWM dimming) (1 Reply)
  3. Adding dashboard for kfs firmware (1 Reply)
  4. KC868-COLB Network Connection (5 Replies)
  5. KC868-COLB Analog Sensor Data in Home Assistant (12 Replies)
  6. KC868-COLB Tuya Integration (10 Replies)
  7. Delay Relay (1 Reply)
  8. KC868-A8: Read voltage on Analog Input A1 to A4 not working? (1 Reply)
  9. Stepper Motor (2 Replies)
  10. Looking for a 4-8 channel ESP32 Energy monitor (1 Reply)
  11. KC686-A6 and KC868-A16 not working INPUTS (3 Replies)
  12. Need Help: SIM7600E Doesn’t Answer Call for Relay Command (3 Replies)
  13. First Steps, need help (5 Replies)
  14. Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple (7 Replies)
  15. KC868-AG GPIO use with KCS firmware (4 Replies)
  16. Chaining IFTTT rules (7 Replies)
  17. B16M reboot when clicking individual switch (10 Replies)
  18. ESP32-S3 Core Board - Disabling LEDs to Lower Power Consumption (3 Replies)
  19. How to let controller connect to your own MQTT cloud server (1 Reply)
  20. RS_485 (3 Replies)
  21. ESP32-S3 Core Board - Resetting when Connecting/Disconnecting USB Serial Cable (5 Replies)
  22. I2C logic levels (9 Replies)
  23. Input protection (5 Replies)
  24. THT22 and 5v (17 Replies)
  25. Using SPI connectors labeled for nRF24L01/LoRA on KC868-A6v3 (1 Reply)
  26. Reset Board ? product reliability (16 Replies)
  27. KC868-A8 (3 Replies)
  28. Modbus CRC mistake (20 Replies)
  29. Explanation of how the inputs and outputs work (0 Replies)
  30. Can't Connect Over LAN (1 Reply)
  31. ModBus RequesMapping Sensors (T1, T2) to ADC Channels on KC868-A6 (3 Replies)
  32. Replacing KCS868-E8 relays with 24V (1 Reply)
  33. kcs firmware system source code (1 Reply)
  34. KC868-A16 - Own Arduino firmware (15 Replies)
  35. DI8 (1 Reply)
  36. esphome - devices connected without ha (3 Replies)
  37. KC868-A8S_WS2812-RGB_LED (4 Replies)
  38. I Need Help Kincony KC868-A8 Integration (3 Replies)
  39. A32Pro problem whit lan and ntp (3 Replies)
  40. KC868-A8 (8 Replies)
  41. KC868-A4S Analog Inputs (2 Replies)
  42. KC868-HAv2 esphome issue (31 Replies)
  43. Lights are not turned on if the dimmer is off button is pressed shortly (1 Reply)
  44. Differences in protocols between H32B and H32B Pro? (2 Replies)
  45. H32B Pro ESB32 pinout? (4 Replies)
  46. PWM output of DC motor drive? (1 Reply)
  47. Humidity and Temperature Sensor (4 wire) (8 Replies)
  48. Board for window contact sensors (15 Replies)
  49. a8s v2 (1 Reply)
  50. USING global VARIABLE IN yaml code (1 Reply)
Pages: 1 2 3
