04-15-2025, 01:41 PM
Hello.
I have a suggestion for your KCSv3. Can you add feature to expose enable/disable switches for each IFTT to MQTT/Home Assistant? Or at least a global enable/disable switch for all IFTT.
I have the A16v3 board I am currently using KCSv3 with home assistant for automation. I want to put more simple IFTT automation in KCSv3 and disable IFTT for normal use, but enable IFTT when power loss. My home assistant and A16v3 have different separate battery backup because they are in different locations. When I have power loss, my home assistant battery backup maybe last 30 minutes maximum, the A16v3 should last a very long time with its own battery backup because very low power consumption. So I want when my home assistant detect power loss, enable IFTT in KCSv3 so that I can have basic automation still running, but when power come back, disable IFTT to have more advanced automation using home assistant. I don't want the IFTT automation clash with home assistant automations.
I also have another question/suggestion.
I am still new and learning about esp32 and Kincony products and features. I follow your website: https://www.kincony.com/how-to-use-kcsv3...board.html to install KCSv3 firmware, but I do not see any instructions on how to update from older version to newer version. Do I repeat the same steps? Can you add in your webpage instructions of how to update KCSv3 from older version to newer version? Does it keep all the settings and IFTT from the older version?
