12-10-2023, 02:47 PM
Yes show unknow in dashboard
KC868-Server integrate to home asssitant by MQTT configuration.yaml
12-11-2023, 01:30 AM
The problem was solved by kincony support team. The cause of the problem was in the settings and configuration of mqtt I had mistakes. Thank you kincony support team i appreciate your efforts.
02-16-2024, 02:07 PM
I am facing the same , used the sample yaml but gives errors. So i had to modify it. but the relays do not respond.
I have changed the code for relay1 but that does not work either. Code: default_config:
02-16-2024, 11:06 PM
all your ' ' is error.
yours: ‘server/7ffd88f939adfbe3340ee686/state’ correct: 'server/7ffd88f939adfbe3340ee686/state' please see clearly at ' '
02-17-2024, 04:42 AM
(02-16-2024, 11:06 PM)admin Wrote: all your ' ' is error. made changes but still not working Code: default_config:
02-17-2024, 12:27 PM
what error information?
| 2 Guest(s) |
