KC868-A16 wiring diagram
#11
yes, you are right, A16 support use by DC24v power supply. DC12v is one of case.
(02-14-2024, 11:23 AM)admin Wrote: yes, you are right, A16 support use by DC24v power supply. DC12v is one of case.
Perfect!!
Thank you very much for the fast reply!!
you are welcome.
For the logical input, I need to use the variant: DC +8-12V is logical "1".
How should I connect the +?V DC voltage input to the A16 input? Can I (must) use the same +12VDC source as the A16 module power supply? Where do I connect the GND on the input terminals?
use by DC12-24v power supply for KC868-A16
digital input can use dry contact signal or DC12-24V.
OK, so I am going use one 24V DC source to power A16 and to (from the same source) +24V to the logic input terminals.
sure , no problem.
I tested both variants on Digital Input:
1/ use dry contact signal [input is connected to GND terminal by button] => logical 1... that's OK.
2/ use of DC +12 [the input is connected by a button to the +12V source of the A16 module] => no change in the input is shown in the Monitor screen. ..here is the error.
according to your description, it should respond to +12V DC (or +24V).
where is the problem? please, send me the wiring diagram for variant 2/.
0v = trigger
12v or 24v = NOT trigger
I don't understand your answer.
In the description of the device A16, you have the input DC 8-12V is logical "1". I bought the A16 mainly because of this information. I have +12V DC voltage outputs from other devices that signal logic "1" and I need to measure them and convert them to HomeAssistant.
