Threads: 0
(01-08-2025, 11:21 PM)admin Wrote: because our firmware design for read DS18B20, so if you connect with DS18B20 as our photo, the LCD will show the value.
OK, I will make sure to order a couple of those. I am still not seeing the device on my WiFi router device list even after updating the network ID and password. Do you have any advice for dealing with this? I have followed your instructions and used the UART Assitant to enter the network ID and password along with MQTT settings, but I do not see the device added to my WiFi network. Is the DS18B20 required to make it connect? I had not expected to need any connected sensors to make it function as a LoRa reciever and MQTT gateway.
Thanks for you help.
Threads: 1,560
now the firmware MUST need connect with DS18B20.
Threads: 0
(01-18-2025, 12:15 AM)admin Wrote: now the firmware MUST need connect with DS18B20.
Thank you for your help. I have ordered a DS18B20, but in the mean time I have been able to purchase the unprotected TMP36 and hooked it up. I was also feeling like there was some other bigger issue so I decided to reflash the board with the ESP Tool and then try resending the setting in the UART Assistant. This seems to have worked! I think there was a bad flash of the Reciever firmware from the start. After that I was struggling to get the board to connect via MQTT to my HA instance on the same network.
I knew things were going in the right direction though since I was getting RECV messages back in the UART display and my board was both assigned an IP and appearing as an attached device on my WiFi network. The ALR display also started to show the mqtt: line along with rssi: and cnt_rcv:, but they were all blank. In other words, the mqtt was not actually connecting to HA. But I could see the device trying to connect to the MQTT broker by checking the log, there was something still not right.
I pulled out one of my NodeMCU boards that I have previsouly used as a MQTT Gateway and checked some of the settings in Arduio IDE for that board and what I noticed is that the mqtt_ip did not have the "http://" preceding the IP or URL. I made the change to my ALR upload and this appears to have fixed the issue! So here are the settings I need to use, in general form, to make my ALR work:
"wifi_name":"NETWORK_ID",
"wifi_psw":"wifipassword",
"mqtt_ip":"192.168.1.10",
"mqtt_port":"1883",
"mqtt_user":"brokerusr",
"mqtt_psw":"password"
I hope this helps others.
Threads: 1,560
thanks share your result.
Threads: 0
02-03-2025, 02:34 PM
(This post was last modified: 02-03-2025, 02:41 PM by wint0178.
Edit Reason: added details
I have purchased and hooked up the DS18B20 probe to my ALR board.
I have been able to get the RECEIVER firmware uploaded using the ESP32 Bootloader Tool AND I have been able to use the UART Assistant App to send my mqtt, and Wifi credentials to the board. At first there was an error with the firmware upload, but once I sorted that out it all seemed to work as described.
The onboard OLED display says that it is connected to my mqtt broker and I am able to see the device in Home Assistant as an attached mqtt device along with all of the potential channels it could be sending data from (ie. Relay, Analog_A1, DS18B20,...), but I do not see any data from the thermometer being displayed on the ALR or sent to HA. Furthermore, I am not able to toggle the relay on the board when I click the on/off buttons in HA. Its clearly connected, but it doesn't seem to be fully connected.
Is the receiver not able to collect its own data from the DS18B20? Does the receiver ALR not provide a functioning relay?
I tried sending the Arduino reciever sketch to the ALR, but was not successful. I thought this would be a great way to program my own mqtt connection, LoRa recieve (based on your work), and include some basic sensor data from the ALR itself.
Any thoughts or insights you have would be greatly appreciated. Thanks!
Threads: 1,560
can you take a photo of your two ALR board? or can you take some video send to whatsapp number: +86-15381188302
Threads: 0
Again a very nice product idea, and i have 1000 use - case in mind.
I like to use several boards to collect data at different locations, maybe power or temperatures.
Would it be possible to connect to a private Lora-wan gateway and transmit the data for all ALRs via Ethernet to home assistant?
Using a receiver for every transmitter seems like a waste of material.
Threads: 1,560
(02-16-2025, 02:54 PM)flomunz Wrote: Again a very nice product idea, and i have 1000 use - case in mind.
if feedback data to Lora-Wan, just need the software, hardware is enough. i have not tried with Lora-wan. You can try with some open source arduino lora-wan project.
Threads: 1
07-24-2025, 07:06 AM
(This post was last modified: 07-24-2025, 08:03 AM by markbrewer.)
Hi, I am able to transfer the transmit firmware to both boards, however when I flash the ALR-Receive firmware ALR-RECEIVER-20240904.ino.merged it uploads but when I reboot the device the KinCony is displayed on the screen. What am I missing?
(07-24-2025, 07:06 AM)markbrewer Wrote: Hi, I am able to transfer the transmit firmware to both boards, however when I flash the ALR-Receive firmware ALR-RECEIVER-20240904.ino.merged it uploads but when I reboot the device the KinCony is displayed on the screen. What am I missing?
Ok it was installing the firmware and was waiting for me to configure the wifi and mqtt settings.
Threads: 1
