Modifying analog Inputs
Hi!
I need 12pcs  0-5V analog inputs for a project and 16 DO.
ESPHome. Home Assistant.
As i see thist product is the most suitable from your catalogue.
But it has 8 0-5V and 8 4-20mA AI-s.
Is it possible to modify the 4-20mA inputs to 0-5V inputs by changing the resistances there to simmilar values like at the 0-5V inputs?
Thanks!!
Daniel
sure, it's ok for change resistances as the 0-5v input channel circuit. every channel replace with two resistances .
(06-27-2025, 12:03 AM)admin Wrote: sure, it's ok for change resistances as the 0-5v input channel circuit. every channel replace with two resistances .
Thanks! Good news!
Do You plan to release new version this product? Like A8-v3?
Thanks!
yes, new version is under designing.
(08-06-2025, 11:59 PM)admin Wrote: yes, new version is under designing.
Good news.  My other devices are the newer so if possible i wouldnt mix them.
I can wait few months. Do you have a target date for production?
Thanks!
Daniel
first version, maybe after 1-2 month.
(08-07-2025, 09:26 PM)admin Wrote: first version, maybe after 1-2 month.
Hi! Do you have maybe any news about the update status? Thank You! Daniel Smile
new version is AIO Hybrid , it already released: https://www.kincony.com/esp32s3-all-in-o...ybrid.html
(10-20-2025, 11:34 PM)admin Wrote: new version is AIO Hybrid , it already released: https://www.kincony.com/esp32s3-all-in-o...ybrid.html
Thanks for fast reply!
I see but it has less analog inputs.
I need the device to a complex heating room wirh many heatpumps and gas boilers.
I have there 12 analog themperature sensors.
Do you have better idea? Or simple buy the old version and modify the inputs as discussed before?
Thaks!
Daniel
if you want use by 12 temperature sensors, you can check TA board, here is details: https://www.kincony.com/esp32-smart-tiny...ystem.html
3 Guest(s)
