KinCony TA (Tiny Alarm System) ESP32-S3 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip and Tuya module. It have 12 channel digital input (12-zone) and 2 channel relay output for sirens or strobe lights, 12 channel 1-wire GPIOs, DS3231 high precision RTC clock chip.TA added Power over Ethernet (PoE). TA have RS485 port and RF433MHz RF receiver. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. TA use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support Apple HomeKit. Tuya mobile phone APP remote monitor 12 channel digital input port state, 12 channel temperature sensors and control 2 channel relay by internet.
Model No. KinCony TA
Description: KinCony ESP32-S3 Tiny Alarm System – TA
Power supply: 12V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6 POE,WiFi,RS485,Bluetooth,USB-C,Tuya Module
Installation method: DIN RAIL
Outputs:
2CH OMRON Relay Outputs, every channel use MAX 5A with COM, NO
Inputs:
12CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
3 buttons: 1:ESP32-S3 Reset 2:ESP32-S3 Download 3:Tuya config
1-Wire GPIO: 12CH (with pull-up resistance on PCB)
433MHz RF Receiver Module
support install on DIN RAIL
software solution:
3. download tasmota firmware.
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=7896
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=7897
ESPHome official supportted list: https://devices.esphome.io/devices/KinCony-TA
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=76
