KinCony MT4 ESP32-S3 4 Channel DC Motor Controller
Overview
KinCony MT4 is a professional 4 Channel DC Motor Controller based on the ESP32-S3-WROOM-1 (N16R8) module. It is designed for smart home automation, industrial automation, DIY IoT projects, motorized curtains, electric valves, linear actuators, robotic systems and other DC motor control applications. Support H-Bridge circuit.
MT4 integrates 4 independent DC motor drivers, RS485, 433MHz RF receiver, IR receiver, I²C expansion interface, 1-Wire GPIO, WiFi, Bluetooth, USB-C, and a Tuya WiFi module into one compact DIN Rail controller.
Whether you are a developer, system integrator, or smart home enthusiast, MT4 provides multiple firmware options, including KinCony KCS v3, ESPHome, Tasmota, Arduino, ESP-IDF, and MicroPython.
Features
- ESP32-S3-WROOM-1 (N16R8) Dual-Core Processor
- 4 Channel DC Motor Driver (L298N)
- Supports Forward / Reverse / Stop control
- Maximum 2A load per motor channel
- Built-in WiFi & Bluetooth
- Built-in Tuya WiFi module
- RS485 interface (Modbus supported by KCS firmware)
- USB Type-C programming interface
- 433MHz RF Receiver
- IR Receiver
- I²C Expansion Port
- 2 Channel 1-Wire GPIO
- DIN Rail installation with plastic enclosure
- Open-source hardware platform
- Supports Arduino IDE
- Supports ESP-IDF
- Supports MicroPython
- Supports ESPHome
- Supports Tasmota
- Home Assistant MQTT Auto Discovery
- Apple HomeKit support (KCS v3 firmware)
Applications
KinCony MT4 is suitable for various automation projects, including:
- Motorized Curtains
- Roller Blinds
- Window Openers
- Electric Valves
- Linear Actuators
- Smart Furniture
- Automatic Doors
- Smart Agriculture
- Industrial Automation
- DIY IoT Projects
- Home Automation Systems
Technical Specifications
| Item | Specification |
| Model | KinCony MT4 |
| Processor | ESP32-S3-WROOM-1 (N16R8) |
| Power Supply | DC 12V |
| Motor Driver | L298N |
| Motor Outputs | 4 Channels |
| Maximum Motor Current | 2A per Channel |
| Communication | WiFi / Bluetooth |
| Interfaces | RS485, USB-C, IR Receiver, 433MHz RF Receiver, I²C Expansion |
| GPIO | 2 Channel 1-Wire GPIO |
| Installation | DIN Rail |
| PCB Size | 87 × 93 mm |
Hardware Interfaces
Outputs
- 4 × DC Motor Outputs
- Maximum Load: 2A per channel
Inputs
- 2 × 1-Wire GPIO
- Built-in pull-up resistors
Buttons
- S1 – ESP32 Reset
- S2 – Download Mode (GPIO0)
- S3 – Tuya Configuration Button
Communication Interfaces
- WiFi
- Bluetooth
- RS485
- USB Type-C
- IR Receiver
- I²C Expansion Interface
Multiple Software Solutions
One of the biggest advantages of KinCony MT4 is the flexibility of firmware selection.
1. KinCony KCS v3 Firmware (Recommended)
KCS v3 firmware is pre-designed for smart home automation and supports multiple communication protocols without programming.
Features include:
- HTTP API
- MQTT
- TCP Server
- RS485 Modbus
- Tuya Smart App
- Local IFTTT Automation (No Internet Required)
- KinCony Cloud Server
- Apple HomeKit Support
With MQTT Auto Discovery enabled, Home Assistant can automatically detect MT4 without writing any YAML configuration.
2. ESPHome
MT4 fully supports ESPHome.
Users can easily integrate the controller into Home Assistant and customize every GPIO according to their own automation requirements.
3. Tasmota
Developers who prefer Tasmota can simply flash the firmware and configure the hardware through the web interface.
4. Arduino IDE
MT4 is completely open for development.
Users can write their own firmware using:
- Arduino IDE
- ESP-IDF
- MicroPython
KinCony provides sample source code and hardware examples to help developers get started quickly.
Recommended Smart Home Solution
For the best user experience, KinCony recommends using Home Assistant together with the Tuya Smart App.
Advantages include:
- Remote control through the Internet using Tuya App
- Local LAN control through Home Assistant
- Faster response
- Better reliability
- Flexible automation
- Voice assistant integration
- Zero-code MQTT discovery
Why Choose KinCony MT4?
✅ Industrial DIN Rail Design
✅ Open Hardware Platform
✅ ESP32-S3 High Performance Processor
✅ Multiple Firmware Choices
✅ Home Assistant Ready
✅ Apple HomeKit Support
✅ Tuya App Compatible
✅ Rich Expansion Interfaces
✅ Open Source Development
✅ Ideal for Smart Home and Industrial Automation
Package Includes
Typical Applications
- Smart Curtains
- Window Automation
- Linear Actuator Control
- Electric Valve Control
- Smart Agriculture
- Smart Factory
- DIY Robotics
- IoT Automation
- Home Assistant Projects
- ESP32 Development
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=9607
KCS v3 firmware download: https://www.kincony.com/forum/forumdisplay.php?fid=75
MT4 ESPHome yaml for home assistant without tuya: https://www.kincony.com/forum/showthread.php?tid=9608
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=115
more photo:
