Precision Current Transformer
Flame retardant properties: Compliant with UL94-VO
Insulation resistance: greater than 1000MQ under normal conditions
Voltage level: 0.66/0.72KV
Pressure resistance strength: 3KV/50Hz/1min
Working frequency: 50/60Hz
Working temperature: -40 ° C~+85 ° C
Sealing material: epoxy resin
some different range model:
DL-CT03CL2.0 aperture 5mm 0-25A cable length: 1 meter
DL-CT08CL10-2000/1 aperture 8.4mm 0-60A cable length: 16cm
DL-CT08CHL18-2000/1 aperture 14.5mm 0-100A cable length: 30cm
Usage: Load current detection, electrical energy metering, microcomputer protection
