KinCony B2 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 2 channel relay output, 4 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B2 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B2 have I2C bus extender and RS485 port. B2 support use SIM7600E 4G module. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B2 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
Model No. KinCony B2
Description: KinCony 2 Channel ESP32-S3 Smart Relay Controller – B2
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD,I2C,Tuya Module, 4G SIM7600
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
2CH relay Outputs, every relay use by MAX AC270V/10A
Inputs:
2CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
software solution:
1. download KinCony KCS v3 firmware, so that work with multi protocols: HTTP, MQTT, Modbus(RS485/TCP), BACnet(RS485/TCP), DMX512, Tuya app, config OUTPUT for “momentary” and “interlock” group functions. use Tuya mobile phone app directly, support voice control by Alexa and Google home speaker directly. if you want local voice control without internet, you can add KinCony AS voice assistant. “KCS” support IFTTT function work locally without internet. It also support use by KinCony cloud server. KCS v3 support home assistant auto discovery function by MQTT, so without any config file for home assistant.
3. download tasmota firmware.
4. write your own arudino or ESP-IDF code for your own requirements.
Order bundles:
Bundle A: B2
Bundle B: B2 + USB-C cable+ DC12V power supply
Bundle C: B2 + USB-C cable+ DC12V power supply + SIM7600E 4G module
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=9683
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=9684
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=117
more details of photo:
manual control buttons work without software, if controller is broken, also can turn on/off output manually.
support install KinCony SIM7600 series 4G module.
SIM card slot.
insert mobile phone SIM card. (NANO)
relay load max AC277V 10A
