kc868-ag mqtt yaml
Bug
i try to use a kc868-ag with home assistant. I didn't find how to register rf comands using esphome. It's easier to register rf comand buttons with kcs firmware. I'm looking for yaml examples to integrate in home assistant using mqtt.
Someone can give some example for yaml setting in home assistant for receiving and sending rf and ir commands through mqtt?
Thank you for your help...
https://www.kincony.com/forum/showthread.php?tid=1899
It is geared towards IR but check out HASSBeam: https://github.com/BasilBerg/hassbeam#hassbeam
I have not tried it yet but seems promising.
I've finally gotten my AG working through ESPhome and manually entered all my codes into the yaml.
Once you get used to it using esphome to learn codes isn't that horrible. You should only have to copy and paste the codes once.
yes, esphome also is easy.
