05-08-2023, 01:19 AM
this is config file for digital input1 with button control KC868-AP output1:
1: click button for ON/OFF LED,
2: hold on button for change led brightness.
type: arduino
encryption:
key: "hx8eSqbwjWs9/2bK0qK55QfTIOpI4gCfzLOeaOXZMaU="
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
sda: 4
scl: 16
- id: 'pcf8574_hub_in_1' # for input channel 1-8 maybe 0x22 / 0x3A
address: 0x22
address: 0x21
pcf8574: pcf8574_hub_in_1
on_click:
then:
- if:
condition:
light.is_off: light_1
then:
light.turn_on:
brightness: 1.0
else:
light.turn_off: light_1
on_press:
then:
- if:
condition:
then:
- delay: 0.5s
- while:
condition:
binary_sensor.is_on: light_1_touch
then:
- light.dim_relative:
relative_brightness: 5%
transition_length: 0.1s
- delay: 0.1s
else:
- delay: 0.5s
- while:
condition:
and:
- binary_sensor.is_on: light_1_touch
- light.is_on: light_1
then:
relative_brightness: -5%
- delay: 0.1s
number: 4
number: 5
number: 6
number: 7
pcf8574: pcf8574_hub_in_2
number: 4
number: 5
number: 6
number: 7
number: 34
number: 35
pca9685:
frequency: 500
output:
- platform: pca9685
pca9685_id: 'pca9685_hub'
channel: 0
- platform: pca9685
channel: 1
- platform: pca9685
channel: 2
- platform: pca9685
channel: 3
- platform: pca9685
channel: 4
- platform: pca9685
channel: 5
- platform: pca9685
channel: 6
- platform: pca9685
channel: 7
- platform: pca9685
channel: 8
- platform: pca9685
channel: 9
- platform: pca9685
channel: 10
- platform: pca9685
channel: 11
- platform: pca9685
channel: 12
- platform: pca9685
channel: 13
- platform: pca9685
channel: 14
- platform: pca9685
channel: 15
light:
- platform: monochromatic
output: PWM0
output: PWM1
output: PWM2
output: PWM3
output: PWM4
output: PWM5
output: PWM6
output: PWM7
output: PWM8
output: PWM9
output: PWM10
output: PWM11
output: PWM12
output: PWM13
output: PWM14
output: PWM15
- platform: rgbw
red: PWM1
green: PWM2
blue: PWM3
white: PWM4
pin: 13
inverted: false
pin: 2
inverted: false
type: arduino
encryption:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
sda: 4
scl: 16
address: 0x22
address: 0x21
on_click:
then:
- if:
condition:
then:
light.turn_on:
brightness: 1.0
else:
on_press:
then:
- if:
condition:
then:
- delay: 0.5s
- while:
condition:
then:
- delay: 0.1s
else:
- delay: 0.5s
- while:
condition:
and:
then:
- delay: 0.1s
number: 4
number: 5
number: 6
number: 7
number: 4
number: 5
number: 6
number: 7
number: 34
number: 35
pca9685:
frequency: 500
output:
- platform: pca9685
channel: 0
- platform: pca9685
channel: 1
- platform: pca9685
channel: 2
- platform: pca9685
channel: 3
- platform: pca9685
channel: 4
- platform: pca9685
channel: 5
- platform: pca9685
channel: 6
- platform: pca9685
channel: 7
- platform: pca9685
channel: 8
- platform: pca9685
channel: 9
- platform: pca9685
channel: 10
- platform: pca9685
channel: 11
- platform: pca9685
channel: 12
- platform: pca9685
channel: 13
- platform: pca9685
channel: 14
- platform: pca9685
channel: 15
light:
output: PWM0
output: PWM1
output: PWM2
output: PWM3
output: PWM4
output: PWM5
output: PWM6
output: PWM7
output: PWM8
output: PWM9
output: PWM10
output: PWM11
output: PWM12
output: PWM13
output: PWM14
output: PWM15
- platform: rgbw
red: PWM1
green: PWM2
blue: PWM3
white: PWM4
pin: 13
inverted: false
pin: 2
inverted: false
