kWh resolution
#11
(02-28-2026, 10:54 AM)Vega Wrote: Completly useless this 1kWh resolution for home usage, will take forever to get a reading. More suitable if you have +100A loads.
Waisted a lot of money for someting what looked nice on paper, next time add the specs and resolutions so we know before we buy.
Despite what admin said, I managed to make software sensor for kWh in ESPhome that is accurate up to 0.001 kWh.
I'm not a programmer, or expert, I used an LLM to make it. But it seems to work fine.
As I stated before, it uses software to calculate kWh instead of hardware components.
Admin can maybe use it in KC software update. Let user decide if they want insensitive 1kWh from hardware or sensitive 1wH from software
The forum doesn't allow me to attach yml file or use more than 1000 characters, so I split the code
  friendly_name: KinconyN30
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
  encryption:
    key: "redacted"
ota:
  - platform: esphome
    password: "redacted"
wifi:
  networks:
    - ssid: !secret wifi_ssid
  ap:
    ssid: "Kinconyn30 Fallback Hotspot"
#ethernet: #Best to choose either wifi or ethernet, both in config active can cause problems
  #type: W5500
  #clk_pin: GPIO42
  #mosi_pin: GPIO43
  #miso_pin: GPIO44
  #cs_pin: GPIO41
  #interrupt_pin: GPIO2
  #reset_pin: GPIO1
captive_portal:
uart:
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
#text_sensor:
  #- platform: ethernet_info
    #ip_address:
      #name: ESP IP Address
      #id: eth_ip
      #address_0:
        #name: ESP IP Address 0
      #address_1:
        #name: ESP IP Address 1
      #address_2:
        #name: ESP IP Address 2
      #address_3:
        #name: ESP IP Address 3
      #address_4:
        #name: ESP IP Address 4
    #dns_address:
      #name: ESP DNS Address
    #mac_address:
      #name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
  sda: 18
  scl: 17
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
  # --- Channels 1.1 to 1.10
  # --- VOLTAGE
  - platform: modbus_controller
    address: 162
    register_type: holding
    name: "N30 Chip 1 Voltage"
    unit_of_measurement: V
    device_class: voltage
    value_type: U_WORD
    filters:
      - multiply: 0.01
    accuracy_decimals: 1
# --- Frequency
    address: 163
    name: "N30 Chip 1 Frequency"
    unit_of_measurement: Hz
    device_class: frequency
    value_type: U_WORD
    filters:
    - multiply: 0.01
# --- Temperature
    address: 164
    name: "N30 Chip 1 Temperature"
    unit_of_measurement: "°C"
    device_class: temperature
    value_type: FP32_R
    address: 100
    name: "N30 1.1 Current"
    unit_of_measurement: A
    value_type: U_DWORD_R
    filters:
      - multiply: 0.001
    accuracy_decimals: 3
    address: 120
    name: "N30 1.1 Power"
    unit_of_measurement: W
    filters:
      - multiply: 0.1
      - filter_out: 5000.0
  - platform: integration
    name: "N30 1.1 Energy"
    sensor: n30_1_p_1
    time_unit: h
    unit_of_measurement: kWh
    device_class: energy
    state_class: total_increasing
    filters:
      - multiply: 0.001
    address: 102
    name: "N30 1.2 Current"
    filters:
      - multiply: 0.001
    address: 122
    name: "N30 1.2 Power"
    filters:
      - multiply: 0.1
    name: "N30 1.2 Energy"
    sensor: n30_1_p_2
    time_unit: h
    filters:
      - multiply: 0.001
    address: 104
    name: "N30 1.3 Current"
    filters:
      - multiply: 0.001
    address: 124
    name: "N30 1.3 Power"
    filters:
      - multiply: 0.1
    name: "N30 1.3 Energy"
    sensor: n30_1_p_3
    time_unit: h
    filters:
      - multiply: 0.001
    address: 106
    name: "N30 1.4 Current"
    filters:
      - multiply: 0.001
    address: 126
    name: "N30 1.4 Power"
    filters:
      - multiply: 0.1
    name: "N30 1.4 Energy"
    sensor: n30_1_p_4
    time_unit: h
    filters:
      - multiply: 0.001
    address: 108
    name: "N30 1.5 Current"
    filters:
      - multiply: 0.001
    address: 128
    name: "N30 1.5 Power"
    filters:
      - multiply: 0.1
    name: "N30 1.5 Energy"
    sensor: n30_1_p_5
    time_unit: h
    filters:
      - multiply: 0.001
    address: 110
    name: "N30 1.6 Current"
    filters:
      - multiply: 0.001
    address: 130
    name: "N30 1.6 Power"
    filters:
      - multiply: 0.1
    name: "N30 1.6 Energy"
    sensor: n30_1_p_6
    time_unit: h
    filters:
      - multiply: 0.001
    address: 112
    name: "N30 1.7 Current"
    filters:
      - multiply: 0.001
    address: 132
    name: "N30 1.7 Power"
    filters:
      - multiply: 0.1
    name: "N30 1.7 Energy"
    sensor: n30_1_p_7
    time_unit: h
    filters:
      - multiply: 0.001
    address: 114
    name: "N30 1.8 Current"
    filters:
      - multiply: 0.001
    address: 134
    name: "N30 1.8 Power"
    filters:
      - multiply: 0.1
    name: "N30 1.8 Energy"
    sensor: n30_1_p_8
    time_unit: h
    filters:
      - multiply: 0.001
    address: 116
    name: "N30 1.9 Current"
    filters:
      - multiply: 0.001
    address: 136
    name: "N30 1.9 Power"
    filters:
      - multiply: 0.1
    name: "N30 1.9 Energy"
    sensor: n30_1_p_9
    time_unit: h
    filters:
      - multiply: 0.001
    address: 118
    name: "N30 1.10 Current"
    filters:
      - multiply: 0.001
    address: 138
    name: "N30 1.10 Power"
    filters:
      - multiply: 0.1
    name: "N30 1.10 Energy"
    sensor: n30_1_p_10
    time_unit: h
    filters:
      - multiply: 0.001
# --- Channels 2.1 to 2.10
  # --- VOLTAGE
    address: 262
    name: "N30 Chip 2 Voltage"
    value_type: U_WORD
    filters:
      - multiply: 0.01
# --- Frequency
    address: 263
    name: "N30 Chip 2 Frequency"
    value_type: U_WORD
    filters:
    - multiply: 0.01
# --- Temperature
    address: 264
    name: "N30 Chip 2 Temperature"
    value_type: FP32_R
    address: 200
    name: "N30 2.1 Current"
    filters:
      - multiply: 0.001
    address: 220
    name: "N30 2.1 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.1 Energy"
    sensor: n30_2_p_1
    time_unit: h
    filters:
      - multiply: 0.001
    address: 202
    name: "N30 2.2 Current"
    filters:
      - multiply: 0.001
    address: 222
    name: "N30 2.2 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.2 Energy"
    sensor: n30_2_p_2
    time_unit: h
    filters:
      - multiply: 0.001
    address: 204
    name: "N30 2.3 Current"
    filters:
      - multiply: 0.001
    address: 224
    name: "N30 2.3 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.3 Energy"
    sensor: n30_2_p_3
    time_unit: h
    filters:
      - multiply: 0.001
    address: 206
    name: "N30 2.4 Current"
    filters:
      - multiply: 0.001
    address: 226
    name: "N30 2.4 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.4 Energy"
    sensor: n30_2_p_4
    time_unit: h
    filters:
      - multiply: 0.001
    address: 208
    name: "N30 2.5 Current"
    filters:
      - multiply: 0.001
    address: 228
    name: "N30 2.5 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.5 Energy"
    sensor: n30_2_p_5
    time_unit: h
    filters:
      - multiply: 0.001
    address: 210
    name: "N30 2.6 Current"
    filters:
      - multiply: 0.001
    address: 230
    name: "N30 2.6 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.6 Energy"
    sensor: n30_2_p_6
    time_unit: h
    filters:
      - multiply: 0.001
    address: 212
    name: "N30 2.7 Current"
    filters:
      - multiply: 0.001
    address: 232
    name: "N30 2.7 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.7 Energy"
    sensor: n30_2_p_7
    time_unit: h
    filters:
      - multiply: 0.001
    address: 214
    name: "N30 2.8 Current"
    filters:
      - multiply: 0.001
    address: 234
    name: "N30 2.8 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.8 Energy"
    sensor: n30_2_p_8
    time_unit: h
    filters:
      - multiply: 0.001
    address: 216
    name: "N30 2.9 Current"
    filters:
      - multiply: 0.001
    address: 236
    name: "N30 2.9 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.9 Energy"
    sensor: n30_2_p_9
    time_unit: h
    filters:
      - multiply: 0.001
    address: 218
    name: "N30 2.10 Current"
    filters:
      - multiply: 0.001
    address: 238
    name: "N30 2.10 Power"
    filters:
      - multiply: 0.1
    name: "N30 2.10 Energy"
    sensor: n30_2_p_10
    time_unit: h
    filters:
      - multiply: 0.001
# --- Channels 3.1 to 3.10
  # --- VOLTAGE
    address: 362
    name: "N30 Chip 3 Voltage"
    value_type: U_WORD
    filters:
      - multiply: 0.01
# --- Frequency
    address: 363
    name: "N30 Chip 3 Frequency"
    value_type: U_WORD
    filters:
    - multiply: 0.01
# --- Temperature
    address: 364
    name: "N30 Chip 3 Temperature"
    value_type: FP32_R
    address: 300
    name: "N30 3.1 Current"
    filters:
      - multiply: 0.001
    address: 320
    name: "N30 3.1 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.1 Energy"
    sensor: n30_3_p_1
    time_unit: h
    filters:
      - multiply: 0.001
    address: 302
    name: "N30 3.2 Current"
    filters:
      - multiply: 0.001
    address: 322
    name: "N30 3.2 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.2 Energy"
    sensor: n30_3_p_2
    time_unit: h
    filters:
      - multiply: 0.001
    address: 304
    name: "N30 3.3 Current"
    filters:
      - multiply: 0.001
    address: 324
    name: "N30 3.3 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.3 Energy"
    sensor: n30_3_p_3
    time_unit: h
    filters:
      - multiply: 0.001
    address: 306
    name: "N30 3.4 Current"
    filters:
      - multiply: 0.001
    address: 326
    name: "N30 3.4 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.4 Energy"
    sensor: n30_3_p_4
    time_unit: h
    filters:
      - multiply: 0.001
    address: 308
    name: "N30 3.5 Current"
    filters:
      - multiply: 0.001
    address: 328
    name: "N30 3.5 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.5 Energy"
    sensor: n30_3_p_5
    time_unit: h
    filters:
      - multiply: 0.001
    address: 310
    name: "N30 3.6 Current"
    filters:
      - multiply: 0.001
    address: 330
    name: "N30 3.6 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.6 Energy"
    sensor: n30_3_p_6
    time_unit: h
    filters:
      - multiply: 0.001
    address: 312
    name: "N30 3.7 Current"
    filters:
      - multiply: 0.001
    address: 332
    name: "N30 3.7 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.7 Energy"
    sensor: n30_3_p_7
    time_unit: h
    filters:
      - multiply: 0.001
    address: 314
    name: "N30 3.8 Current"
    filters:
      - multiply: 0.001
    address: 334
    name: "N30 3.8 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.8 Energy"
    sensor: n30_3_p_8
    time_unit: h
    filters:
      - multiply: 0.001
    address: 316
    name: "N30 3.9 Current"
    filters:
      - multiply: 0.001
    address: 336
    name: "N30 3.9 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.9 Energy"
    sensor: n30_3_p_9
    time_unit: h
    filters:
      - multiply: 0.001
    address: 318
    name: "N30 3.10 Current"
    filters:
      - multiply: 0.001
    address: 338
    name: "N30 3.10 Power"
    filters:
      - multiply: 0.1
    name: "N30 3.10 Energy"
    sensor: n30_3_p_10
    time_unit: h
    filters:
      - multiply: 0.001
thanks share your code.
we will try to update ARM CPU fimrware, let kwh work with 0.001 maybe next update will do this.
now new ARM CPU update firmware, support 0.001kwh now.
https://www.kincony.com/forum/showthread.php?tid=9107
Installed the new ARM firmware, but now are the readings very strange.
Also installed the adjusted yaml file for esphome.
Also reseted the values with the N60_APP
[Image: Screenshot-2026-03-08-003834.png][Image: Screenshot-2026-03-08-003905.png]
This is a part of your yaml file
    address: 100
    device_class: current
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    device_class: power
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    address: 140
    address: 142
    address: 144
    address: 160
    address: 162
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    unit_of_measurement: °C
    value_type: FP32_R
first time, need use PC software to clear energy data. esphome yaml and KCS v3 firmware will update soon. Now under developing.
in ARM CPU before energy data define by "uint32_t", now change to "float".
after clear data, MUST need re power on of board. Then will begin count with 0 energy meter data.
(03-08-2026, 06:05 AM)admin Wrote: first time, need use PC software to clear energy data. esphome yaml and KCS v3 firmware will update soon. Now under developing.
Already did that.
[Image: Screenshot-2026-03-08-134756.png]
Is the ESPhome yaml still correct or need that be changed?
