04-20-2024, 02:16 PM
Since a few days I have been having problems with the analog outputs on my KC868-AIO. (KC868-AIO-EXTAO--V1.2)
channels 1 to 6 work normally
Channels 7 and 8 are off and no longer respond to anything. (the LEDs on the PCB are also off. With a voltmeter I measure 0V on the output)
channel 9 works normally.
Channels 10 and 11 are off and no longer respond to anything. (the LEDs on the PCB burn at 100%. With a voltmeter I measure 11.72V on the output)
When other channels are at 100% I measure 10.2V on the output.
channels 12 to 16 work normally.
When I disconnect all outputs, the above remains the same.
All other inputs and outputs work normally.
I have no idea what happened.
My configuration has not changed.
All outputs are connected to the exact same type of dimmers.
What else can I test?
Is there something wrong with the "KC868-AIO-EXTAO--V1.2" board?
Thank you in advance!
