KC-868 A16 output strange behaviour
#11
ok, good.
Can I connect ON/OFF switch parralel with A16 output if I want manual override output state?
NO, it's not a good way.
(08-12-2024, 11:07 PM)admin Wrote: NO, it's not a good way.
Can you give an other solution?
switch buttons should connect to digital input ports, then make IFTTT command for AUTOMATION.
(08-14-2024, 12:57 PM)admin Wrote: switch buttons should connect to digital input ports, then make IFTTT command for AUTOMATION.
But if board is broken! or other SW error? Is disconnect output connector only way to manualy get heating on.
do you use a extend relay with A16?
if YES, you can manual control the extend relay's coin.
