Retain Switch status ESPHome after reboot and update / Ethernet setup
Information
Hi
if i update the boards A64 / A128 the outputs does not retain their status so if i have switch-1 on and reboot the switch-1 goes off
i run ESPHome true Home Assistant and run the automations true node-red is there a possibility to have it retain the previous state before reboot or update
Also i want to use my ethernet but it wont connect
  friendly_name: Kincony KC868-A64-RK
    type: arduino
  encryption:
    key: "xxxx"
ota:
  password: "xxx"
  platform: esphome
#wifi:
#  ssid: !secret wifi_ssid
#  password: !secret wifi_password
#  # Enable fallback hotspot (captive portal) in case wifi connection fails
#  ap:
#    ssid: "Kincony-Kc868-A64-Rk"
#    password: !secret wifi_ap
#captive_portal:
  - id: bus_a
    sda: 5
    scl: 16
    frequency: 400kHz
  - id: bus_b
    sda: 15
    scl: 4
    frequency: 400kHz
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 20.20.20.192
    gateway: 20.20.20.1
    subnet: 255.255.255.0
Thanks in advance
Sijmen
do you want use KC868-A64 and KC868-A128 work with ESPHome, but need retain the previous OUTPUT state after re power on?
(10-13-2024, 11:06 AM)admin Wrote: do you want use KC868-A64 and KC868-A128 work with ESPHome, but need retain the previous OUTPUT state after re power on?
Yes
i got both boards
the switch yaml code you can add "restore_mode" for that.
fox example:
pin: GPIO12 # your relay GPIO
restore_mode: RESTORE_DEFAULT_ON # or RESTORE_DEFAULT_OFF or ALWAYS_OFF/ALWAYS_ON
here is ESPHome about "restore_mode" setting details: https://esphome.io/components/switch/index.html
(10-14-2024, 10:34 AM)admin Wrote: the switch yaml code you can add "restore_mode" for that.
fox example:
So like this
      pcf8574: pcf8574_hub_out_5
      mode: OUTPUT
yes
3 Guest(s)
