AC voltage and calibration
#31
I found a project which with almost the same hardware calculates real and apparent power.
https://github.com/danpeig/ESP32EnergyMonitor
@admin
Can we do the same on M16 v2?
thanks for the link, but I don't understand yet how they define the power factor.
@sanurss: also read this one about SCT013 low power accuracy: https://www.casler.org/wordpress/low-cur...he-sct013/
Thanks for the article, I have SCT013 clamps and according to schematics the shield is not connected...
https://www.poweruc.pl/products/split-co...6754706476
Looking at M16v2 schematics I see some capacitor connected to the clamp but it seems to be to the ground rather between signal pins. Unfortunately it doesn't seem to be so easy to fix now.
@admin Do you have Arduino code that calculates apparent and active power as well as power factor for M16?
sorry, only have arduino Calibrate code for AC voltage.
I have an m16v2 card. The mains voltage is detected about 10V lower.
I tried adjusting "define SENSITIVITY" both higher and lower, but it doesn't seem to change the displayed voltage. Is it necessary to restart the card or is it enough to restart Home Assistant?
