  • 1 Vote(s) - 5 Average
how to integrate KC868-A8 to home assistant by MQTT
#31
set the threshold value for every sensor in KCS sensor webpage.
so that will auto update to mqtt message when tempetature changed value.
(09-28-2025, 10:50 PM)admin Wrote: set the threshold value for every sensor in KCS sensor webpage.
Yes, that was 1st thing to do, unfortunately without preogress.
Honestly, I did not update firmware recently, perhaps that can be an issue.. ? it is still on v2.2.2
the firmware too old. please download newest KCS v2 firmware: https://www.kincony.com/forum/showthread.php?tid=8267
(10-02-2025, 10:44 PM)admin Wrote: the firmware too old. please download newest KCS v2 firmware: https://www.kincony.com/forum/showthread.php?tid=8267
Hello again,
 Firmware updated, unfortunately, now it does not communicate at all with HA.
All credentials are set (user, pass, IP, port) but no luck.
I used v2.2.14, several times downloading stopped due to comm error, can be a cable or something else, but process was finished, everything else is working except MQTT :-)
Log from MQTT:
2025-10-04 09:26:46: Client <unknown> disconnected due to protocol error.
[09:26:48] INFO: Successfully send discovery information to Home Assistant.
[09:26:50] INFO: Successfully send service information to the Supervisor.
2025-10-04 09:26:53: New connection from 172.30.32.1:48335 on port 1883.
2025-10-04 09:26:53: New client connected from 172.30.32.1:48335 as 0BnDBQigbsncamiStHmizu (p2, c1, k60, u'mqtt').
2025-10-04 09:27:16: New connection from 172.30.32.2:56082 on port 1883.
2025-10-04 09:27:16: Client <unknown> closed its connection.
2025-10-04 09:27:24: New connection from 172.30.32.1:54105 on port 1883.
2025-10-04 09:27:24: New client connected from 172.30.32.1:54105 as 5kunAzYa87n16r4Y5BCCyD (p2, c1, k60, u'mqtt-user').
2025-10-04 09:27:25: Client 5kunAzYa87n16r4Y5BCCyD disconnected.
2025-10-04 09:27:25: Client 0BnDBQigbsncamiStHmizu disconnected.
2025-10-04 09:27:25: New connection from 172.30.32.1:48293 on port 1883.
2025-10-04 09:27:25: New client connected from 172.30.32.1:48293 as 0ca9UAol92FRsGjaOXn4nR (p2, c1, k60, u'mqtt-user').
2025-10-04 09:27:25: Client 0ca9UAol92FRsGjaOXn4nR disconnected.
2025-10-04 09:27:25: New connection from 172.30.32.1:42013 on port 1883.
2025-10-04 09:27:25: New client connected from 172.30.32.1:42013 as 2e7LdLhHfwMgdJaO4vEPbz (p2, c1, k60, u'mqtt-user').
2025-10-04 09:27:51: Client 2e7LdLhHfwMgdJaO4vEPbz closed its connection.
2025-10-04 09:28:26: New connection from 172.30.32.1:46545 on port 1883.
2025-10-04 09:28:26: New client connected from 172.30.32.1:46545 as 7ARl5WtqMIJTUwmchaGa06 (p2, c1, k60, u'mqtt-user').
take a photo of your mqtt setting for KC868-A8
(10-04-2025, 11:02 PM)admin Wrote: take a photo of your mqtt setting for KC868-A8
This are the snapshots:
Somehow message appears in listen mode, but sporadic, not constant communication. only for Output_1
Solved,
Stupid mistake in IP, it should be with mqtt://.   :-)
Thanks, everything works fine now !
yes, this is issue.
I followed your presentation at the beginning of this treat. For the setting in the kincony part,I could follow all steps.
Unfortunately when you switch to the homeassistant screen, I cannot follow it anymore. I cannot not find the board in the ' entity' and the left part op the screen in empty. I cannot find the file configuration.yaml.
Which step I forgot ?
take a photo or video of your problem.
