  • 1 Vote(s) - 3 Average
[Arduino IDE demo source code for KC868-A32]--#07-KC868-A32_Web_server_code
.zip   KC868-A32_Web_Server.zip (Size: 483.68 KB / Downloads: 1,049)
* Create Your own WebServer for KC868-A32 Smart Controller*
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0   // reset wifi button
WiFiManager wm;
// Replace with your network credential
/* const char* ssid     = "xxx"; //your router's ssid
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
PCF8574 pcf8574_R1(&I2Ctwo, 0x24, 15, 13);
PCF8574 pcf8574_R2(&I2Ctwo, 0x25, 15, 13);
PCF8574 pcf8574_R3(&I2Ctwo, 0x21, 15, 13);
PCF8574 pcf8574_R4(&I2Ctwo, 0x22, 15, 13);
PCF8574 pcf8574_I1(&I2Cone, 0x24, 4, 5);
PCF8574 pcf8574_I2(&I2Cone, 0x25, 4, 5);
PCF8574 pcf8574_I3(&I2Cone, 0x21, 4, 5);
PCF8574 pcf8574_I4(&I2Cone, 0x22, 4, 5);
String relaystate[32]={
  "relay1state","relay2state","relay3state","relay4state","relay5state","relay6state","relay7state","relay8state",
  "relay9state","relay10state","relay11state","relay12state","relay13state","relay14state","relay15state","relay16state",
  "relay17state","relay18state","relay19state","relay20state","relay21state","relay22state","relay23state","relay24state",
  "relay25state","relay26state","relay27state","relay18state","relay296state","relay30state","relay31state","relay32state",
String relay32state = "off";// state of relay32
  for(int i=0;i<=7;i++)
     pcf8574_R3.pinMode(i, OUTPUT);
     pcf8574_R4.pinMode(i, OUTPUT);
  pcf8574_R1.begin();
  pcf8574_R2.begin();
  pcf8574_R3.begin();
  pcf8574_R4.begin();
  for(int i=0;i<=7;i++){
  pcf8574_I1.pinMode(i, INPUT);
  pcf8574_I2.pinMode(i, INPUT);
  pcf8574_I3.pinMode(i, INPUT);
  pcf8574_I4.pinMode(i, INPUT);
pcf8574_I1.begin();
pcf8574_I2.begin();
pcf8574_I3.begin();
pcf8574_I4.begin();
    pcf8574_R3.digitalWrite(i, HIGH);
    pcf8574_R4.digitalWrite(i, HIGH);
// Connect to Wi-Fi network with SSID and password
// Serial.print("Connecting to ");
// Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  //WiFi.begin(ssid, password);
     bool res;
    // res = wm.autoConnect(); // auto generated AP name from chipid
       res = wm.autoConnect("KC868-A32-AP"); // anonymous ap
   //  res = wm.autoConnect("AutoConnectAP","password"); // password protected ap
    if(!res) {
        // ESP.restart();
    else {
  /*while (WiFi.status() != WL_CONNECTED) {
     // delay(10);
    //Serial.print(".");
  Serial.println("");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
    currentTime = millis();
    previousTime = currentTime;
        header += c;
            client.println();
            // turns 16 relays on and off
            else if (header.indexOf("GET /17/on") >= 0)  {relay17state = "on";pcf8574_R3.digitalWrite(P0, LOW);}
            else if (header.indexOf("GET /17/off") >= 0) {relay17state = "off";pcf8574_R3.digitalWrite(P0, HIGH);}
            else if (header.indexOf("GET /18/on") >= 0)  {relay18state = "on";pcf8574_R3.digitalWrite(P1, LOW);}
            else if (header.indexOf("GET /18/off") >= 0) {relay18state = "off";pcf8574_R3.digitalWrite(P1, HIGH);}
            else if (header.indexOf("GET /19/on") >= 0)  {relay19state = "on";pcf8574_R3.digitalWrite(P2, LOW);}
            else if (header.indexOf("GET /19/off") >= 0) {relay19state = "off";pcf8574_R3.digitalWrite(P2, HIGH);}
            else if (header.indexOf("GET /20/on") >= 0)  {relay20state = "on";pcf8574_R3.digitalWrite(P3, LOW);}
            else if (header.indexOf("GET /20/off") >= 0) {relay20state = "off";pcf8574_R3.digitalWrite(P3, HIGH);}
            else if (header.indexOf("GET /21/on") >= 0)  {relay21state = "on";pcf8574_R3.digitalWrite(P4, LOW);}
            else if (header.indexOf("GET /21/off") >= 0) {relay21state = "off";pcf8574_R3.digitalWrite(P4, HIGH);}
            else if (header.indexOf("GET /22/on") >= 0)  {relay22state = "on";pcf8574_R3.digitalWrite(P5, LOW);}
            else if (header.indexOf("GET /22/off") >= 0) {relay22state = "off";pcf8574_R3.digitalWrite(P5, HIGH);}
            else if (header.indexOf("GET /23/on") >= 0)  {relay23state = "on";pcf8574_R3.digitalWrite(P6, LOW);}
            else if (header.indexOf("GET /23/off") >= 0) {relay23state = "off";pcf8574_R3.digitalWrite(P6, HIGH);}
            else if (header.indexOf("GET /24/on") >= 0)  {relay24state = "on";pcf8574_R3.digitalWrite(P7, LOW);}
            else if (header.indexOf("GET /24/off") >= 0) {relay24state = "off";pcf8574_R3.digitalWrite(P7, HIGH);}
            else if (header.indexOf("GET /25/on") >= 0)  {relay25state = "on";pcf8574_R4.digitalWrite(P0, LOW);}
            else if (header.indexOf("GET /25/off") >= 0) {relay25state = "off";pcf8574_R4.digitalWrite(P0, HIGH);}
            else if (header.indexOf("GET /26/on") >= 0)  {relay26state = "on";pcf8574_R4.digitalWrite(P1, LOW);}
            else if (header.indexOf("GET /26/off") >= 0) {relay26state = "off";pcf8574_R4.digitalWrite(P1, HIGH);}
            else if (header.indexOf("GET /27/on") >= 0)  {relay27state = "on";pcf8574_R4.digitalWrite(P2, LOW);}
            else if (header.indexOf("GET /27/off") >= 0) {relay27state = "off";pcf8574_R4.digitalWrite(P2, HIGH);}
            else if (header.indexOf("GET /28/on") >= 0)  {relay28state = "on";pcf8574_R4.digitalWrite(P3, LOW);}
            else if (header.indexOf("GET /28/off") >= 0) {relay28state = "off";pcf8574_R4.digitalWrite(P3, HIGH);}
            else if (header.indexOf("GET /29/on") >= 0)  {relay29state = "on";pcf8574_R4.digitalWrite(P4, LOW);}
            else if (header.indexOf("GET /29/off") >= 0) {relay29state = "off";pcf8574_R4.digitalWrite(P4, HIGH);}
            else if (header.indexOf("GET /30/on") >= 0)  {relay30state = "on";pcf8574_R4.digitalWrite(P5, LOW);}
            else if (header.indexOf("GET /30/off") >= 0) {relay30state = "off";pcf8574_R4.digitalWrite(P5, HIGH);}
            else if (header.indexOf("GET /31/on") >= 0)  {relay31state = "on";pcf8574_R4.digitalWrite(P6, LOW);}
            else if (header.indexOf("GET /31/off") >= 0) {relay31state = "off";pcf8574_R4.digitalWrite(P6, HIGH);}
            else if (header.indexOf("GET /32/on") >= 0)  {relay32state = "on";pcf8574_R4.digitalWrite(P7, LOW);}
            else if (header.indexOf("GET /32/off") >= 0) {relay32state = "off";pcf8574_R4.digitalWrite(P7, HIGH);}
               /* for(int i=0;i<32;i++)
                relaystate[i]="on";
              relay17state = "on";// state of relay1
              relay18state = "on";// state of relay2
              relay19state = "on";// state of relay3
              relay20state = "on";// state of relay4
              relay21state = "on";// state of relay5
              relay22state = "on";// state of relay6
              relay23state = "on";// state of relay7
              relay24state = "on";// state of relay8
              relay25state = "on";// state of relay9
              relay26state = "on";// state of relay10
              relay27state = "on";// state of relay11
              relay28state = "on";// state of relay12
              relay29state = "on";// state of relay13
              relay30state = "on";// state of relay14
              relay31state = "on";// state of relay15
              relay32state = "on";// state of relay16
                 pcf8574_R1.digitalWrite(i,LOW);
                 pcf8574_R2.digitalWrite(i,LOW);
                 pcf8574_R3.digitalWrite(i,LOW);
                 pcf8574_R4.digitalWrite(i,LOW);
              /*for(int i=0;i<32;i++)
                relaystate[i]="off";
              relay17state = "off";// state of relay1
              relay18state = "off";// state of relay2
              relay19state = "off";// state of relay3
              relay20state = "off";// state of relay4
              relay21state = "off";// state of relay5
              relay22state = "off";// state of relay6
              relay23state = "off";// state of relay7
              relay24state = "off";// state of relay8
              relay25state = "off";// state of relay9
              relay26state = "off";// state of relay10
              relay27state = "off";// state of relay11
              relay28state = "off";// state of relay12
              relay29state = "off";// state of relay13
              relay30state = "off";// state of relay14
              relay31state = "off";// state of relay15
              relay32state = "off";// state of relay16
            // Display the HTML web page
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            //client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            //client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button { background-color: #195B10; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 35px; margin: 2px; cursor: pointer;}");
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state + " relay17:" + relay17state + " relay18:" + relay18state + " relay19:" + relay19state + " relay20:" + relay20state + " relay21:" + relay21state + " relay22:" + relay22state + " relay23:" + relay23state + " relay24:" + relay24state + " relay25:" + relay25state + " relay26:" + relay26state + " relay27:" + relay27state + " relay28:" + relay28state + " relay29:" + relay29state + " relay30:" + relay30state + " relay31:" + relay31state + " relay32:" + relay32state);
            else
            // Web Page Heading
           client.println("<body><h1>KC868-A32 Web Server</h1>");
            if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">09-OFF</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">09-ON </button></a>");
            if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-OFF</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10-ON</button></a>");
            if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-OFF</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11-ON</button></a>");
            if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-OFF</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12-ON</button></a>");
            if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-OFF</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13-ON</button></a>");
            if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-OFF</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14-ON</button></a>");
            if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-OFF</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15-ON</button></a>");
            if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-OFF</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16-ON</button></a>");
            if (relay17state == "off") client.println("<a href=\"/17/on\"><button class=\"button\">17-OFF</button></a>"); else client.println("<a href=\"/17/off\"><button class=\"button\">17-ON</button></a>");
            if (relay18state == "off") client.println("<a href=\"/18/on\"><button class=\"button\">18-OFF</button></a>"); else client.println("<a href=\"/18/off\"><button class=\"button\">18-ON</button></a>");
            if (relay19state == "off") client.println("<a href=\"/19/on\"><button class=\"button\">19-OFF</button></a>"); else client.println("<a href=\"/19/off\"><button class=\"button\">19-ON</button></a>");
            if (relay20state == "off") client.println("<a href=\"/20/on\"><button class=\"button\">20-OFF</button></a>"); else client.println("<a href=\"/20/off\"><button class=\"button\">20-ON</button></a>");
            if (relay21state == "off") client.println("<a href=\"/21/on\"><button class=\"button\">21-OFF</button></a>"); else client.println("<a href=\"/21/off\"><button class=\"button\">21-ON</button></a>");
            if (relay22state == "off") client.println("<a href=\"/22/on\"><button class=\"button\">22-OFF</button></a>"); else client.println("<a href=\"/22/off\"><button class=\"button\">22-ON</button></a>");
            if (relay23state == "off") client.println("<a href=\"/23/on\"><button class=\"button\">23-OFF</button></a>"); else client.println("<a href=\"/23/off\"><button class=\"button\">23-ON</button></a>");
            if (relay24state == "off") client.println("<a href=\"/24/on\"><button class=\"button\">24-OFF</button></a>"); else client.println("<a href=\"/24/off\"><button class=\"button\">24-ON</button></a>");
            if (relay25state == "off") client.println("<a href=\"/25/on\"><button class=\"button\">25-OFF</button></a>"); else client.println("<a href=\"/25/off\"><button class=\"button\">25-ON</button></a>");
            if (relay26state == "off") client.println("<a href=\"/26/on\"><button class=\"button\">26-OFF</button></a>"); else client.println("<a href=\"/26/off\"><button class=\"button\">26-ON</button></a>");
            if (relay27state == "off") client.println("<a href=\"/27/on\"><button class=\"button\">27-OFF</button></a>"); else client.println("<a href=\"/27/off\"><button class=\"button\">27-ON</button></a>");
            if (relay28state == "off") client.println("<a href=\"/28/on\"><button class=\"button\">28-OFF</button></a>"); else client.println("<a href=\"/28/off\"><button class=\"button\">28-ON</button></a>");
            if (relay29state == "off") client.println("<a href=\"/29/on\"><button class=\"button\">29-OFF</button></a>"); else client.println("<a href=\"/29/off\"><button class=\"button\">29-ON</button></a>");
            if (relay30state == "off") client.println("<a href=\"/30/on\"><button class=\"button\">30-OFF</button></a>"); else client.println("<a href=\"/30/off\"><button class=\"button\">30-ON</button></a>");
            if (relay31state == "off") client.println("<a href=\"/31/on\"><button class=\"button\">31-OFF</button></a>"); else client.println("<a href=\"/31/off\"><button class=\"button\">31-ON</button></a>");
            if (relay32state == "off") client.println("<a href=\"/32/on\"><button class=\"button\">32-OFF</button></a>"); else client.println("<a href=\"/32/off\"><button class=\"button\">32-ON</button></a>");
              client.println("<a href=\"/all/on\"><button class=\"button\">all ON</button></a>");
              client.println("<a href=\"/all/off\"><button class=\"button\">all OFF</button></a>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(pcf8574_I1.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I1.digitalRead(i) == LOW)       //key pressed again
    if(pcf8574_I2.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I2.digitalRead(i) == LOW)       //key pressed again
          pcf8574_R2.digitalWrite(i,!pcf8574_R2.digitalRead(i));    // toggle relay1 state
          while(pcf8574_I2.digitalRead(i) == LOW); //wait remove hand
          if (pcf8574_R2.digitalRead(i) == LOW) relaystate[i+9]="on";else relaystate[i+9]="off";
    if(pcf8574_I3.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I3.digitalRead(i) == LOW)       //key pressed again
          pcf8574_R3.digitalWrite(i,!pcf8574_R3.digitalRead(i));    // toggle relay1 state
          while(pcf8574_I3.digitalRead(i) == LOW); //wait remove hand
          if (pcf8574_R3.digitalRead(i) == LOW) relaystate[i+17]="on";else relaystate[i+17]="off";
    if(pcf8574_I4.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I4.digitalRead(i) == LOW)       //key pressed again
          pcf8574_R4.digitalWrite(i,!pcf8574_R4.digitalRead(i));    // toggle relay1 state
          while(pcf8574_I4.digitalRead(i) == LOW); //wait remove hand
          if (pcf8574_R4.digitalRead(i) == LOW) relaystate[i+25]="on";else relaystate[i+25]="off";
According to page below, I should select my specific esp8266 board:
https://www.kincony.com/build-esp8266-web-serve.html
According to page below the product KC868-A32 uses Espressif ESP32:
https://tr.aliexpress.com/item/1005004042030033.html
But I couldnot find it on below menu:
Arduino IDE 2.0.4 > Tools > Board > esp8266 > ...
Could you help me on selecting the correct board.
if you use KC868-A32, it made by "ESP32" , chose "NodeMcu-32S" board.
(03-02-2023, 01:57 PM)admin Wrote: if you use KC868-A32, it made by "ESP32" , chose "NodeMcu-32S" board.
According to tutorial below
with ref: http://arduino.esp8266.com/stable/packag...index.json
I could not see "NodeMcu-32S"
Then I found your tutorial
Lesson1-config Arduino IDE for ESP32 module (kincony.com)
with ref:  https://dl.espressif.com/dl/package_esp32_index.json
There is a "NodeMcu-32S" option. And as you said it is made by esp32
Thanks
do you have instsalled "esp32" board in arduino IDE?
(03-03-2023, 09:03 AM)admin Wrote: do you have instsalled "esp32" board in arduino IDE?
I made a clean-up by following here
Then I extracted arudino from the zip file from here
Then I add esp32 boards by following here (link updated)
Then I selected NodeMCU-32S under the menu esp32 as below (is it answer to your question?).
But there is a compile error:
Using board 'nodemcu-32s' from platform in folder: C:\Users\tugal\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\tugal\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\\me\\codes\\arduino\\KinCony\\KC868-A32_Web_Server\\partitions.csv" copy /y "C:\\me\\codes\\arduino\\KinCony\\KC868-A32_Web_Server\\partitions.csv" "C:\\Users\\tugal\\AppData\\Local\\Temp\\arduino\\sketches\\02B740C2A58FB97419BB0D488CA3EC52\\partitions.csv"
cmd /c if not exist "C:\\Users\\tugal\\AppData\\Local\\Temp\\arduino\\sketches\\02B740C2A58FB97419BB0D488CA3EC52\\partitions.csv" copy "C:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\tools\\partitions\\default.csv" "C:\\Users\\tugal\\AppData\\Local\\Temp\\arduino\\sketches\\02B740C2A58FB97419BB0D488CA3EC52\\partitions.csv"
        1 file(s) copied.
Detecting libraries used...
"C:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-
IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NodeMCU_32S -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NodeMCU_32S\"" "-DARDUINO_VARIANT=\"nodemcu-32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\nodemcu-32s" "C:\\Users\\tugal\\AppData\\Local\\Temp\\arduino\\sketches\\02B740C2A58FB97419BB0D488CA3EC52\\sketch\\KC868-A32_Web_Server.ino.cpp" -o nul
Alternatives for WiFi.h: [WiFi@1.0]
ResolveLibrary(WiFi.h)
  -> candidates: [WiFi@1.0]
IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NodeMCU_32S -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NodeMCU_32S\"" "-DARDUINO_VARIANT=\"nodemcu-32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\nodemcu-32s" "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "C:\\Users\\tugal\\AppData\\Local\\Temp\\arduino\\sketches\\02B740C2A58FB97419BB0D488CA3EC52\\sketch\\KC868-A32_Web_Server.ino.cpp" -o nul
Alternatives for PCF8574.h: [PCF8574 library@2.3.5]
ResolveLibrary(PCF8574.h)
  -> candidates: [PCF8574 library@2.3.5]
IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NodeMCU_32S -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NodeMCU_32S\"" "-DARDUINO_VARIANT=\"nodemcu-32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\nodemcu-32s" "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "-Ic:\\me\\docs\\Arduino\\libraries\\PCF8574_library" "C:\\Users\\tugal\\AppData\\Local\\Temp\\arduino\\sketches\\02B740C2A58FB97419BB0D488CA3EC52\\sketch\\KC868-A32_Web_Server.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0.1]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0.1]
IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NodeMCU_32S -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NodeMCU_32S\"" "-DARDUINO_VARIANT=\"nodemcu-32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\nodemcu-32s" "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\WiFi\\src" "-Ic:\\me\\docs\\Arduino\\libraries\\PCF8574_library" "-IC:\\Users\\tugal\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries\\Wire\\src" "C:\\Users\\tugal\\AppData\\Local\\Temp\\arduino\\sketches\\02B740C2A58FB97419BB0D488CA3EC52\\sketch\\KC868-A32_Web_Server.ino.cpp" -o nul
Alternatives for WiFiManager.h: []
ResolveLibrary(WiFiManager.h)
  -> candidates: []
C:\me\codes\arduino\KinCony\KC868-A32_Web_Server\KC868-A32_Web_Server.ino:9:26: fatal error: WiFiManager.h: No such file or directory
compilation terminated.
Using library WiFi at version 1.0 in folder: C:\Users\tugal\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Using library PCF8574 library at version 2.3.5 in folder: C:\me\docs\Arduino\libraries\PCF8574_library
Using library Wire at version 1.0.1 in folder: C:\Users\tugal\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire
exit status 1
Compilation error: WiFiManager.h: No such file or directory
I tried every board under the menu esp32 that has "esp32" in its name. But the error persists.
check this version.
Board Manager: Yes I checked it. esp32 is version 1.0.6.
Library Manager: I think header files are related with library manager. Now, for no reason, it started giving me below error
Compilation error: PCF8574.h: No such file or directory
I need to find which libraries should i install to use the above example.
you need install this PCF8574 arduino library.
here is download file for you.
.zip   PCF8574_library.zip (Size: 23.8 MB / Downloads: 1,030)
(03-04-2023, 11:07 PM)admin Wrote: you need install this PCF8574 arduino library.
I have put the PCF8574 library, under library folder, under sketchbook location.
For my case it is C:\me\codes\arduino\libraries
And it worked.
But, now the below compile error came back.
