03-14-2023, 11:14 AM
KC868-H32B blinds motor control and connect
03-14-2023, 11:18 AM
"interlock" function will let some relay never ON at the same time. (user can preset by user which relay work with "interlock")
08-08-2023, 09:00 AM
(03-14-2023, 10:27 AM)admin Wrote: ok, if you want use "interlock" function, you can update. Hello, Unfortunately, I didin't manage to update. The problem I have is with manual switching blinds motor. Currently I have to press 2 times UP (first time to turn ON relay for UP and second time to turn OFF relay for UP), thank I can press DOWN to go go down.. How can I adjust my HS32BS and E16 to have functionality of "motor mode" as described in video: https://www.kincony.com/%E3%80%90iot-tra...smart.html. Furthermore, in case of "motor mode", how do I stop blinds, for example, a half way UP or DOWN.
08-08-2023, 01:28 PM
H32BS have "interlock" function , you can set which two channel relay of your blind motor.
E16S also have "interlock" function when you download "KCS" firmware.
