KC868-A6 ESP32 I/O pin define
#define ANALOG_A1  36
#define ANALOG_A2  39
#define ANALOG_A3  34
#define ANALOG_A4  35
DS18B20/DHT11/DHT21/LED strip -1: 32
DAC1:26
DAC2:25
IIC SDA:4
IIC SCL:15
Input_IIC_address 0x22
Relay_IIC_address 0x24
RS485 RXD: 14
RS485 TXD: 27
SPI_Bus: (For LoRA/nRF24L01)
CS: 5
MOSI: 23
MISO: 19
SCK: 18
LoRA sx1278:
RST:21
DIO0:2
nRF24L01:
CE: 22
RS485:
TXD:27
RXD:14
RS232:
TXD:17
RXD:16
Extend serial port on PCB:
TXD(define by yourself):12
RXD (define by yourself) :13
(06-01-2022, 07:23 AM)admin Wrote: #define ANALOG_A1  36
DAC1:26
DAC2:25
IIC SDA:4
IIC SCL:15
RS485 RXD: 14
RS485 TXD: 27
CS: 5
MOSI: 23
MISO: 19
SCK: 18
LoRA sx1278:
RST:14
DIO0:21
nRF24L01:
CE: 22
RS485:
TXD:27
RXD:14
RS232:
TXD:17
RXD:16
I would like to use IO-1/IO-2 (originally intended for sensors ect. DS1820) as pure GIPO. Huh
I understand that I have to remove two resistors from the print.
I need to use the board to communicate with the furnace via OpenTherm. What pins should I use for input/output?
Design https://ihormelnyk.com/opentherm_adapter
IO1 and IO2 in KC868-A6 can use for DS18B20 directly.
(10-22-2023, 12:27 AM)admin Wrote: IO1 and IO2 in KC868-A6 can use for DS18B20 directly.
No one of this firmwares worked.
ESP dont expose WIFI SSID
download KCS v2 firmware for KC868-A6
(04-09-2025, 11:39 PM)admin Wrote: download KCS v2 firmware for KC868-A6
thanks!
im was in a old version of KCS.
Now im using KCS_KC868_A6_V2.2.12 and its working fine!
Do you have any datasheet for the HTTP server and other protocols functions? i already have the MQTT protocol datasheet.
https://www.kincony.com/forum/showthread.php?tid=3106
