Threads: 1
how big is the KC868-A16?
If you order with the box, how big is it then? And does it have DIN rail fitting?
How big will the KC868-A32 be? Will it also come with a box and din fitting? what is the size?
Threads: 1
any plans for a KC868-E32? would be a good combo
Threads: 684
if make a E32, 32 channel relay will be very long, how about ?
Threads: 1
Oh yes. That would be very long haha. Maybe you can give me an idea then.
I have 60 switches that work on 24v now (can change to 12v) that control the same amount of relay's (60 relays). Any tip how I can use kincony gear for these?
In combination with Home Assistant. I don't have ethernet in my electrictal cabin.
Threads: 684
i think you can use KC868-H32BS:2pcs
if you really want to write program code by yourself, such as ESPHome , arduino IDE, then you can chose KC868-A16 or A32 in furture, extend relay module just use KC868-E16:4pcs. because almost the size: 32 channel = 16 cahnnel *2
