K868-Uair proper GPIO assignation ?
#11
(03-13-2022, 01:37 AM)admin Wrote: i think you need to check software, hardware is no problem, here is some our demo images.
Did you get a look at code I use ? You'll see it's good and it's clearly device that has a wiring problem on board !!
your code have problem, i already told you the reason and give you the correct code, just use it!
GPIO33 use for 1 LED !!!
GPIO32 use for 4 LED
you have define all is "4"! Do you understand?
(03-14-2022, 11:19 AM)admin Wrote: GPIO33 use for 1 LED !!!
Yep but it doesn't change the problem as it's a bad layout problem in device itself !! When the bar is on one of the ring led doesn't follow anymore the ring !! Default of product design, sorry to say Sad
