KC868-A6 ESPHome demo config for home assistant
(06-01-2022, 07:25 AM)admin Wrote: esphome:
    type: arduino
ota:
  password: "b9c07c109b7ecc6c63dac976c0c23a12"
wifi:
  ssid: KinCony
  password: xxxxxxxx
  ap:
    ssid: "A6 Fallback Hotspot"
    password: "GLdHSsZr1p96"
captive_portal:
  sda: 4
  scl: 15
    address: 0x24
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
do you have the modbus code example for sensor in ESPHome with KC868-A6 ?
Thanks,
RE: KC868-A6 ESPHome demo config for home assistant - by cesarblancartelizarraga - 02-03-2023, 05:14 PM
