02-12-2023, 12:55 AM
thanks for your help.
KC868-A128 configure for ESPhome
12-03-2023, 09:08 PM
I tried to update esp home server but I can't upload yaml file. I don't know why. ESP sever showing offline. I used 3 network cables. 2 are on KC868 server and 1 is connecting on A128.
Please give me some advice. Thank you! Updating /config/esphome/kc868-server.yaml ------------------------------------------------------------ INFO ESPHome 2023.11.6 INFO Reading configuration /config/esphome/kc868-server.yaml... WARNING GPIO5 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-a...pping-pins WARNING GPIO5 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-a...pping-pins WARNING GPIO15 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-a...pping-pins WARNING GPIO15 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-a...pping-pins INFO Generating C++ source... INFO Compiling app... Processing a128 (board: esp32dev; framework: arduino; platform: platformio/espressif32@5.4.0) -------------------------------------------------------------------------------- HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5 Dependency Graph |-- WiFi @ 2.0.0 |-- ESPmDNS @ 2.0.0 |-- Wire @ 2.0.0 RAM: [= ] 11.2% (used 36744 bytes from 327680 bytes) Flash: [=== ] 33.9% (used 622121 bytes from 1835008 bytes) ========================= [SUCCESS] Took 11.32 seconds ========================= INFO Successfully compiled program. ERROR Cannot upload Over the Air as the config does not include the ota: component ======== [ERROR] /config/esphome/kc868-server.yaml ======== ======================== [SUMMARY] ======================== - /config/esphome/kc868-server.yaml: FAILED
12-04-2023, 02:25 AM
can you take a video send to whatsapp number: +86-15381188302
12-04-2023, 04:57 AM
12-04-2023, 08:14 AM
post your "kc868-server.yaml" file at here.
Users browsing this thread: |
