DS1307 RTC
#11
yes, you should set i2c pins first step, then your program code will use that setting as default. here is photo, just do as photo.
Thank you for the clarification.
It means that I don't need to define SDA & SCL in my sketch, correct??
I see that SS in your explanation below SDA & SCL also use i2c pin 5, is not a conflict as my sketch don't find the RTC module connected.
It means that I don't need to define SDA & SCL in my sketch, correct?? yes, just define in "pins_arduino.h".
What about pin 5 used twice, both the SCL and below in SS in the "pins_arduini.h"
Is that not a conflict?
yes, need use two different, i just tell you which two pins for I2C need preset.
(04-10-2023, 04:29 AM)admin Wrote: yes, need use two different, i just tell you which two pins for I2C need preset.
What pin to use here instead of pin 5
A16 board, not use SPI bus, you can delete it or write any other GPIO number.
