Digital inputs
Hello everyone ! Is it possible to connect a 3.3V input to one of the connectors of the module?
you can try, maybe 3.3v will not trigger.
(06-12-2023, 09:59 PM)admin Wrote: you can try, maybe 3.3v will not trigger.
Looking at the schematic from DI-1 to DI-6 they are activated with 0V since the common is +12V. But maybe you could help me if I use them in the analog inputs, I just want to know if I can make this connection, my reference voltage is 0 - 3.3 V it is the voltage of the KINCONY A6 board ... thanks in advance ..
It's solved! I just wanted an advice or opinion from the manufacturer! I have connected the analog input A1, but I have configured it as a digital input in the program! it works perfectly ! thank you !
ok, good.
