Kc868-a8e
#11
Hey, it works, the generator turns on and off. Where can I connect the 12v battery?
sorry, i don't understand you, some times you said not work, now you said it work. i don't know what you want to do now?
Sorry for all the confusion. Now we managed to arrange the rf433 with the generator, it works perfectly. In addition, I want to measure the volt of the 13.6 or 27 volt caravan battery Where can I connect so that I can see in the application not through esphome
board only support analog input port voltage range DC 0-5v.
So what do you suggest I do? You're not willing to open the ic2 application for me so I can connect ina226. I don't want esphome. Or if you can give me an esphome file with all the recording options rf433 and ic2 with setting of ina226 and with an option that I can create the desired automation as I wrote
when voltage>27v relay ON?
when voltage<13.6v relay OFF?
13.6volt send rf433 generator -off
12.1v - send rf433-on generator
