kc868-a32m Ethernet issue with Tasmota
hi,
Please assist
I have installed Tasmota32 version 13.1.0 on the kc868-a32m but the ethernet port is not working. The ethernet port leds do not show any activity.
regards,
you can download tasmota firmware and see online guide at here : https://www.kincony.com/forum/showthread.php?tid=1931
(09-14-2023, 10:31 PM)admin Wrote: you can download tasmota firmware and see online guide at here : https://www.kincony.com/forum/showthread.php?tid=1931
hi,
I followed the guide but the template code from the guide does not seem to work for the A32M.
{"NAME":"KC868-A32","GPIO":[32,0,1120,0,641,609,0,0,0,608,1,640,0,0,5600,0,0,0,0,5568,0,0,0,0,0,0,0,0,1,1,0,0,1,0,0,1],"FLAG":0,"BASE":1}
After saving the code, the option to Configure PCF8574 disappears from the tasmota configuration menu. Using the template code for A16 seems to work. I just changed NAME to KC868-A32 on A16 template code
{"NAME":"KC868-A32","GPIO":[32,0,1120,0,640,608,0,0,0,1,1,1152,0,0,5600,0,0,0,0,5568,0,0,0,0,0,0,0,0,1,1,0,0,1,0,0,1],"FLAG":0,"BASE":1}
I then followed the rest of the steps.
not need to use template. suggest you download any tasmota firmware, just enabled ETHERNET option's firmware. you can download newest tasmota firmware from tasmota official webpage.
