03-25-2025, 04:50 PM
I flash m'y T16M with the esp tools in Ubuntu following the procedure I found on the forum.
I put the KCS V3 firmware
But now when I plug the board to my router I am not able to find the ip. The orange led in ethernet port on the board blink. The green one is off.
I can not use the discovery tool, because I am on linux.
Do you have a tool to recommande.
I also search to connect to the wifi Access point. But It does not appear. I read that I have to press a button to re enable the wifi Access point, but which button (I saw dw and reset near antenna), and how to proceed (press before power on, at anytime...).
Thanks for your help
