KC868-A4S and meanwell ELG-200-24B
I'm trying to use meanwell ELG-200-24B to drive 24v LED drive strips using A4S and the LED does not completely turn off. When I checked, there is ~0.58V across the analog output and ground.
What am I doing wrong?
KC868-D16 dimmer controller + driver is suitable for dimmable LED strip.
@Geometry Dash The most likely cause of your issue is the KC868-A4S outputting a residual voltage (~0.58V) when set to “off,” which is above the ELG-200-24B’s dimming threshold, preventing the LEDs from turning off completely. Start by isolating the KC868-A4S output and verifying its behavior, then proceed with the appropriate fix.
